Wegeng_Haus
Oct 29 2018, 05:23 AM
I'm looking for opinions on the value of a 7R 911 engine case, fully machined and Case Savers installed by Ollie's? Thanks.
BK911
Oct 29 2018, 06:24 AM
2.4 or 2.7?
sithot
Oct 29 2018, 07:27 AM
QUOTE(BK911 @ Oct 29 2018, 08:24 AM)
2.4 or 2.7?
Starting point, perhaps.
http://forums.pelicanparts.com/porsche-911...974-1976-a.html
IronHillRestorations
Oct 29 2018, 07:52 AM
If you have receipts for machine work, and detailing what was done; probably $8-1200 depending. This is hard to research fair market value. You might call Ollie's and see if they can help put a value. Pelican or Early S page is probably going to be a better site for it selling it though.
Is this Dave?
tornik550
Oct 29 2018, 07:56 AM
I know that I paid about $2000 to Ollies to have my 7r cleaned, fully machined, case savers and bypass modification. That was just for the work so $1200 for your case seems low to me.
Mark Henry
Oct 29 2018, 08:43 AM
Funny thing is less than 8 years ago I could't give away a known running 2.7 disassembled core with a std/std magnafluxed crank for $1000 (asking was $1200).
I just said fuch it and packed it away, it's my backup engine or hopefully I'll find a home for it one day. I pick away at small jobs on it from time to time, heads are half done and I'm collecting small parts.
With all the other cores becoming spendy the 2.7 is finally getting some love.
BK911
Oct 29 2018, 09:55 AM
A 2.4 7R case is worth some coin.
At least $2k as a core.
2.7 not so much.
larryM
Oct 29 2018, 08:22 PM
QUOTE(BK911 @ Oct 29 2018, 08:55 AM)
2.7 not so much.
why do you say that?
why is one 7R worse a than another?
iirc - a late 7R with the upgraded oil passages or mod is about the best of 'em
ConeDodger
Oct 29 2018, 08:29 PM
QUOTE(IronHillRestorations @ Oct 29 2018, 10:52 AM)
Is this Dave?
Dave’s not here man...
gereed75
Oct 29 2018, 09:46 PM
Most consider the 2.4 to be potentially less stressed than a 2.7, both physically and heat stressed.
I think that if it is a good 7R (with all the studs) it is worth at least $1000 plus the worth of Ollie’s machine work. These things work fine for a street motor build IMHO.
This also assumes that you have the rest of everything you need to put the whole thing together. Trying to piecemeal one of these together gets very pricy. Better to start with a good long block core. There was a recent thread on this in the classifieds
jasons
Oct 30 2018, 06:00 AM
The 2.4 is just way more rare. I think they were only around for half of 73 for the short run of CIS 2.4's. Because of the bore size, they are the case of choice for people looking to build hot rod 2.4ish motors. The rarity of the bore size drives the price, not better or worse.
I sold a 2.4 7R long block core to a member here for like $1k a bunch of years ago. That was before the Porsche price bubble. Ironically, the engine code on that one was MFI so it must have been right at the cut in of MFI to CIS.
brant
Oct 30 2018, 07:29 AM
also the 2.4 case has small spigots and can be down sized into 2.0
The 7r case 2.1 race motors are stronger than a 3r/5r race motor
Oct 30 2018, 07:43 AM
Multiple people are getting into the replacement case market. Billet aluminum cases. Heavier than Mag but much stronger and ready to build right out of the box. Won't be cheap but Mag has a short working life that gets shorter when heated. The aluminum cases should last our lifetime and beyond.
GeorgeRud
Oct 30 2018, 07:55 AM
I’d check with the folks on the Pelican Parts 911 Forum for opinions as well.
sithot
Oct 30 2018, 08:19 AM
QUOTE(mepstein @ Oct 30 2018, 09:43 AM)
There's a guy touting his replacement 6 cylinder cases but as yet not one has been produced for the market.
Billet VW cases are another matter. Were I in the market to do a hot rod I'd consider the
914 4R"000 Build" in the latest 000 magazine. Shooting for 1700 pounds.
From the article the author makes a valid point that the six is around 110 pounds heavier than the 4 and it only gets heavier with displacement.
I'm not a POLO engine buyer because the output doesn't justify the price. A FAT engine suites me. I know they work from my friends experience with his 2.8 which was the scourge of the autocross scene and FTD at the PCA Parade in 2008. They've only gotten better.
Oct 30 2018, 08:41 AM
QUOTE(sithot @ Oct 30 2018, 10:19 AM)
That's more of a 4 vs 6 thing. 99.99% of 911 owners will never put a 4 in their car and the PO is asking about the value of a 6 case. I think the more desirable cases will become less desirable once the replacement 6 cylinder case market opens up. Every other part is now available aftermarket so it was just a matter of time before cases were made. I know we are talking about an upscale market but that is sort of the definition of Porsche.
The 962 at our shop uses a 3.0 turbo case as a base for it's 780hp. The new billet cases should be even stronger.
gcrotvik
Oct 30 2018, 08:50 AM
I paid $1,500 for a 2.4 7R case with no machine work done to it 2 years ago and that was a deal.
brant
Oct 30 2018, 11:00 AM
the 2.7 case is still not a high dollar or high value case
reworked helps a lot
and most people will no bother to build a 2.7 when they can buy an aluminum 3.0 motor for less than the rebuild.
some folks that are racing a specific class, or going for originality will use the 2.7 case. but its not the most desirable case unfortunately.
seanery
Oct 30 2018, 06:56 PM
Tell me more, where I can I research these?
Oct 30 2018, 07:36 PM
QUOTE(seanery @ Oct 30 2018, 08:56 PM)
This post on pelican list a couple of the guys doing it.
https://forums.pelicanparts.com/911-engine-...ric-racing.htmlThe downside is that you could get the case for free and you are still looking at an expensive engine to build. Crank, rods, heads, pistons & cylinders, dual dizzy, fan & shroud, bearings, oil pump, ect. will still cost tens of thousands if you buy new. Even if you buy used parts it will be $10-15K aditional. We did a 3.8 for a customer and it was $80K in parts. I learned from my cycling days its always more expensive to build piece by piece than to by a product and modify. If $15-20K for a 3.6 is beyond your budget, building on a new case makes it look cheap.
But I love that these guys are bringing more product to the market. There will be plenty of people who can afford it.
seanery
Oct 30 2018, 08:47 PM
I just found the guy who's been working on the 3.6 case halves on a Rennlist thread, looks like a promising project! I can't wait til he does the mag case replacements!
QUOTE(mepstein @ Oct 30 2018, 10:36 PM)
horizontally-opposed
Oct 30 2018, 10:01 PM
QUOTE(ConeDodger @ Oct 29 2018, 07:29 PM)
LOL.
ConeDodger
Oct 30 2018, 10:03 PM
QUOTE(horizontally-opposed @ Oct 31 2018, 01:01 AM)
LOL.
Oh good. Someone finally got it!
porschetub
Oct 30 2018, 10:11 PM
QUOTE(gcrotvik @ Oct 31 2018, 03:50 AM)
Totally a 2k minimum case any day the case work will add $$$ but its about finding a buyer.
sithot
Oct 31 2018, 05:58 AM
2.7 is as far as anyone should take any mag case.
Larmo63
Oct 31 2018, 09:53 AM
The completely rebuilt engine I bought as a 2.7 for my conversion was found through an ad in the back of Panorama.
I made the deal over the phone, it shipped and I went to work on getting the car prepped for it; motor mounts, oil tank install, oil cooler, etc.
When we decided to bore out the heads and manifolds from 32mm to 36mm, we discovered that the pistons were 83.9mm so 2.4 displacement.
At first, I was a bit pissed that it wasn't the 2.7 I thought I had bought as advertised, but now I feel that a 2.4 really suits the car. It is plenty fast, sounds really sexy, and does not run hot. Nothing compares to the sound of a vintage 911 engine at full song. It brings back old memories of these cars that I used to hear growing up.
I had installed an oil cooler set up for the 2.7, so that is there keeping things cool.
My engine is an early 2.4T Euro case, built to S specs. Lots of fun!
seanery
Oct 31 2018, 03:33 PM
Does the 2.4T have the noncounterweighted crank like the 2.2T? If so, did you replace your crank? I have a 2.2T that is destined for one of my 914s, rebuilt to a 2.5E or S spec, but damn, cranks are expensive these days!!
QUOTE(Larmo63 @ Oct 31 2018, 12:53 PM)
Larmo63
Oct 31 2018, 11:54 PM
I did a boroscope look-see when I bought the engine, but I don't recall the crank specs.
mb911
Nov 1 2018, 05:40 AM
QUOTE(seanery @ Oct 31 2018, 01:33 PM)
All 2.4s are counterweighted as they are the same crank as a 2.7.
seanery
Nov 1 2018, 06:44 AM
Thanks Ben!
QUOTE(mb911 @ Nov 1 2018, 08:40 AM)
BK911
Nov 1 2018, 07:51 AM
QUOTE(seanery @ Oct 31 2018, 05:33 PM)
What is a 2.5?
A 2.7 bore with a 2.2 stroke?
Or a 2.4 with 85mm cylinders?
If the former, not sure you want to start with a 2.2T case.
seanery
Nov 1 2018, 11:55 PM
I’ve got a 2.2T that is destined to go in the car, but I’ve also got a 7R case and some bits. Ultimately it will be a short stroke with 2.7 sized jugs.
[quote name='BK911' date='Nov 1 2018, 10:51 AM' post='2662016']
[qu[b]ote name='seanery' post='2661851' date='Oct 31 2018, 05:33 PM']
[quote name='Larmo63' post='2661779' date='Oct 31 2018, 12:53 PM']
[/quote]
[/quote]
What is a 2.5?
[/quote]
Front yard mechanic
Nov 2 2018, 06:16 AM
So now that you have multiple opinions is the case for sale or is it going to be used for art
Wegeng_Haus
Nov 3 2018, 11:07 AM
QUOTE(BK911 @ Oct 29 2018, 07:24 AM)
2.4 or 2.7?
Hmmm, not sure, guess I'd better find out.
Wegeng_Haus
Nov 3 2018, 11:14 AM
QUOTE(Front yard mechanic @ Nov 2 2018, 07:16 AM)
I've been hanging onto this thing for 30 or so years and ran across it recently. Funny you say that, because I was gonna put a glass top on it and make it a coffee table. I'm just trying to decide if I wanna spend the $ to send it to Ollie's. Thanks for all the responses.
Mark Henry
Nov 3 2018, 12:53 PM
QUOTE(Wegeng_Haus @ Nov 3 2018, 01:14 PM)
I wanted to this, the wife asked if I was planning on moving out....
Wegeng_Haus
Nov 10 2018, 10:48 AM
QUOTE(IronHillRestorations @ Oct 29 2018, 07:52 AM)
Is this Dave?
Hi, Perry. Yes, it's Dave. I called Ollie's and they guessed they'd charge around $3k for cleaning, oil by-pass mods, case savers, shuffle pins, redecking of both halves and welding a broken gusset between two bearing lands.
sixnotfour
Nov 10 2018, 11:32 AM
I have 2.7 case all the tricks from ollies.... yearly rebuild..found a crack straight down through the main web, one case half.... coffee table gold
Nov 10 2018, 08:47 PM
Hi Dave! I still have that 914 silver bracelet you made. Doesn't fit my wife though, so never worn.
My guess, is that the cost of getting one fixed exceeds the fair market value.
So unless you find a buyer that must have that case, it's probably $2-2500 to the right guy maybe the $3k. At that point wouldn't you just find a case for next to nothing and have it all fixed?
Nov 10 2018, 10:26 PM
QUOTE(sixnotfour @ Nov 10 2018, 12:32 PM)
That's a bummer. Mag only gets more brittle with age.
sixnotfour
Nov 11 2018, 02:40 AM
I just sent them a numbers matching -6 case..to weld up a spun main ...$2900
Nov 11 2018, 05:57 AM
QUOTE(sixnotfour @ Nov 11 2018, 03:40 AM)
We sent them a 69S case for the same thing. $10k case but still a mag case.
porschetub
Nov 11 2018, 11:41 PM
QUOTE(seanery @ Nov 1 2018, 10:33 AM)
http://www.914world.com/bbs2/style_images/...ages/indent.gifNothing wrong with crankshafts from the 2.2 just folks being dictated by what they read on the net.
Top engine builders are using them (66mm) with larger bores to good result,check to see whats happening @ Supertec think the 2.4 was the first to use the larger throw crank as far as I remember but could be wrong .
stownsen914
Nov 13 2018, 12:43 PM
I've been reading about the aftermarket 911 cases over on Pelican - one guy is doing a cast version and another guy is now in the mix doing billet early cases. No one has mentioned cost yet. Not cheap, I'm sure. I'm guessing $10-20K? Anyone know?
Nov 13 2018, 01:16 PM
QUOTE(stownsen914 @ Nov 13 2018, 01:43 PM)
Catorze is a world member doing the 3.6 case. I think he is shooting for $5K.
stownsen914
Nov 13 2018, 01:36 PM
QUOTE(mepstein @ Nov 13 2018, 02:16 PM)
That's actually not bad if it's really ready to go at that price. It's easy to drop $3-4K between purchasing a 911 case and then having all the work done to make it go to go.
Nov 13 2018, 01:49 PM
QUOTE(stownsen914 @ Nov 13 2018, 02:36 PM)
Once there is a good supply of cases, I believe there will be more aftermarket manufacturers of parts to complete the engines.
Wegeng_Haus
Dec 7 2018, 08:57 AM
QUOTE(Front yard mechanic @ Nov 2 2018, 06:16 AM)
Breaking news: I checked the case serial number with factory records and it is a 1975, 2.7 "S" case, also the same specs as a '75 USA Carrera. I'm still not sure what to do with this thing. All opinions welcome.
Mark Henry
Dec 7 2018, 03:43 PM
QUOTE(Wegeng_Haus @ Dec 7 2018, 09:57 AM)
IIRC 75-77 they are all "S" cases, nothing special.
brant
Dec 7 2018, 03:57 PM
QUOTE(Mark Henry @ Dec 7 2018, 02:43 PM)
I believe the 1975's were all thermal reactor cars in the US. And the cases from that year were considered the least desirable as they have all been thermally stressed by the reactors.
