milwlandrover
Nov 2 2018, 07:01 AM
I went to my local Napa store to buy a cap and rotor. I bought the one they found on the computer and it was not in stock so they said they would call when it came in. (3) days later I stopped in when they didn't call and they said it was in so I took it home. WRONG the rotor was twice as big and the cap didn't fit either. Took it back and they re-ordered and said it would be in the next day. I went the next day and they said it was not in but they would call me. A week later I stopped in and they said they could not find my order but they found the parts. I took them home. WRONG AGAIN. So I thought I would order through Pelican Parts (who I should have called in the first place, but... Now I am ordering the part for a 914-4 1971 1.7L and the picture looks different then what I have so I am nervous.
mobymutt
Nov 2 2018, 07:13 AM
I had similar troubles. I didn't realize my car had a non-stock distributor. First thing to do is to find the part number on the distributor body that you have.
bbrock
Nov 2 2018, 07:28 AM
The Pelican part you show has a rev limiter which is what I would want and is the correct rotor. Should work fine.
milwlandrover
Nov 2 2018, 07:57 AM
but will it fit my distributor?
bbrock
Nov 2 2018, 08:36 AM
QUOTE(milwlandrover @ Nov 2 2018, 07:57 AM)
If it is a stock dizzy, it should. Either style works, but the original rotors had the rev limiter. There was a recent thread on them.
milwlandrover
Nov 2 2018, 09:07 AM
I have to check tonight if I have a stock distributor. It looks like I may not and that is why Napa got the wrong parts twice. he may have gotten the correct parts for a stock distributor.
dr914@autoatlanta.com
Nov 2 2018, 09:08 AM
for stock 914 fuel injection ask for Bosch 03010 and 04030
QUOTE(milwlandrover @ Nov 2 2018, 06:01 AM)
milwlandrover
Nov 2 2018, 09:25 AM
I have no doubt those are the correct parts for a stock distributor but if I have (as some have suggested) I have a non-stock distributor they would not necessarily fit... correct?
milwlandrover
brant
Nov 2 2018, 09:37 AM
Is your car still running stock Djet?
or is your car now carb'd?
if stock FI, there really are not many optional distributors you could even have. I think you would know if you had a 123 distributor that you had put on. Otherwise it almost has to be a stock distributor
if you have carbs, there are lots of optional distributors you could have on the car. a stock one, a 009, an 050, etc.... etc...
milwlandrover
Nov 2 2018, 09:55 AM
I am still fuel injected, but my distributor rotor is completely different then the rev limited one that is stock. if you look at the pictures they look different. Which lets me to believe it is a non stock distributor. The car was purchased this summer and the previous owner did some crazy stuff. Some good some bad. The worst part is when I try to replace things I don't know what
brant
Nov 2 2018, 10:03 AM
rev rotors look different than non rev rotors
I didn't look at your pics
but a stock Fuel injection distributor also houses the fuel injection trigger points. If your car is fuel injected and able to run.... then it must be either a stock distributor or a 123 distributor.
the 123 distributors have only been on the market for 3 or so years.
so unless a previous owner installed a 123 within about the last 3 years.... you have to have a stock distributor.
how long have you had your car?
does it run on stock FI?
then you have a stock distributor
ask someone reading this thread to snap a picture of a non rev limiting stock rotor.
bet it looks just like yours.
milwlandrover
Nov 2 2018, 10:11 AM
It is still fuel injected and it was running quite will (I did 300 miles last weeks end). It started a little hard (especially when it was cold - but not below 40 degrees) so I changed the plugs and wires. I wanted to also change the cap and rotor and new points as long as I was in there and before I put it away for winter. The rotor I took out was totally different then the ones ordered by Napa and the one that Pelican says is the stock rotor looks even more different.
milwlandrover
Nov 2 2018, 10:13 AM
milwlandrover
Nov 2 2018, 10:31 AM
I just searched the part number for the Napa rotor that I just got and it looks like the original but doesn't fit. it says it is NOT REV LIMITED. So, I figure the previous owner installed a distributor for a carbureted car on my fuel injected car. Does that make sense or would the car not even run with the wrong distributor?
Nov 2 2018, 10:37 AM
would not run, needs to have trigger points in the base of the distributor and all trigger point 311 and 914s have the same rotor, 311s have shorter distributor caps but they all fit
Just get the two part numbers I stated and you will be all set
quote name='milwlandrover' date='Nov 2 2018, 09:31 AM' post='2662393']
[/quote]
milwlandrover
Nov 2 2018, 10:38 AM
I'm thinking maybe I should just replace the distributor with the correct one and the correct cap and rotor and be sure everything is cool. What are your thoughts.
bbrock
Nov 2 2018, 10:43 AM
QUOTE(milwlandrover @ Nov 2 2018, 10:31 AM)
At least on DJet FI, the distributor has trigger points at the base for the injectors and carburetor injectors won't work. I've never owned or worked on Ljet FI so don't know if it is the same.
From the pictures you posted, the rotors I would get from my FLAP for the stock distributor looked like your NAPA pic and they worked fine except didn't have the rev limiter. Either style from the pics you posted will work, but different rotors for different dizzies come in the same style. Just think of those styles as basic vs. deluxe.
My guess is the Pelican rotor will work for you and is better IMO than the non-rev limiting rotor.
brant
Nov 2 2018, 11:45 AM
QUOTE(milwlandrover @ Nov 2 2018, 10:38 AM)
if your car runs
then you already have the correct distributor
pull the part number and verify if you want
but I bet that if you order parts from Pelican everything will be fine
brant
milwlandrover
Nov 2 2018, 02:22 PM
where can I find the part number on the distributor I have. Can I see it on the distributor on the car?
brant
Nov 2 2018, 03:01 PM
I would recommend you not take the distributor out.
its not that hard.
but also can be reinstalled incorrectly and effect timing
definitely will have to be re-timed at a minimum if you pull it
best not to pull it
the part number is on the body of the distributor
google images might help with an example.
mobymutt
Nov 2 2018, 04:05 PM
QUOTE(milwlandrover @ Nov 2 2018, 04:22 PM)
I just stuck a phone down beside the distributor and took random pictures until I could see the part number. No need to remove it.
bbrock
Nov 2 2018, 04:47 PM
A super simple thing to do without pulling the dizzy is to look for the connector for the trigger points. If it has a harness plugged into a connector like the black socket at the top of the dizzy in this pic, then it is a stock dizzy. Carb dizzies won't have that connector. Note also this dizzy is fitted with a non-rev limiting rotor like what you have now.
