QUOTE(Highland @ Nov 2 2018, 11:27 AM)
Thanks for the input. Problem is I don't know what position to start counting 30 turns.
With my luck when I power up my lights will home at half open. Not a big deal, it would just be cool to get them close now.
Leave the lever arms detached until you have power. Same goes for the bolt/nut that hold the "stop" since the stop actually isn't to stop the motor at all!
As mentioned above, once you have power, cycle the motors a few times (Again, with the lever detached and no stop bolt).
Then, with the lights on, pull the relay to the motor, then attach the lever and set the "stop" (which is only used to prevent the light from wiggling when open, *not* to stop the motor).
But most importantly, whatever you do, keep your fingers away from the lever when you have power to the motor, only work on the lever with the relay removed.
That motor has enough torque to strip the flesh right off your fingers!
