As stated - there was a factory center lapbelt, & you could probably put in an aftermarket lapbelt in there too.
Probably better to put an adult there in the middle, & 3 across isn't too tight,as they were marketed as a 2+1 with the center belt option. Your 4 across is pick-em-up truck action! LOL
.... unless they were 2-3 with a nice looking gal in the middle next to you, to share shifting duties with you, & serve as an armrest!
Click to view attachment Hitting Reverse by mistake - well not so bad if you're stopped - but never good in motion!
... think meat grinder on metal gears!
Get your shifter adjusted & make sure that the "Reverse Lock" is intact & working properly. That reverse lock should require enough pressure that you'd have really push extra hard to get it into R instead of 2nd!
These 901 transmissions with the dog-leg 1st were specifically designed by Porsche for their race cars, because they only used 1st to leave the pits, & that pattern left the 4 most used 2nd - 4th gears in the traditional "H" pattern for easiest access to those 4 gears in a race.
If you're hitting R instead of 2nd or 3rd, then either your reverse lock is shot/missing/mis-adjusted, or else you're really forcing it, instead of letting the shift find the gates in a more normal way.
A shifting mental trick which an old school SCCA 914 racer told me about back in the 70's, is to push 1st to 2nd toward the center-to-right side of heater sliders, & 3rd to 4th towards the left radio knob (or the spot where the cut-out is if no radio).
Take some time to practice up on the shifting action, if the reverse lock & shifter/bushings/etc. are properly operating/adjusted & you're still having issues.
Cheers!
Tom
