Chi-town
Nov 11 2018, 01:48 PM
QUOTE(betz @ Nov 10 2018, 04:17 PM)
I've been sick the past few days, but I couldn't help but fuss with the 914 a bit.
Got a couple of suspicious things going on. I plugged the fuel pump in, but with the ignition on it does not power the fuel pump. I have the supply line disconnected, and even tried cranking but no fuel is coming out.
Tested voltage at the fuel pump plug, I'm reading 6V. Don't know why it's not 12.. and seems a little suspicious that it's exactly half. Tomorrow I'll try putting in the new bosch 69133 fuel pump. If it doesn't work ill just jump the wires... maybe put a switch in like a race car lol.
But yeah, at this point I'm thinking, sort out the fuel pump and It'll probably run. Hopefully.
Check all your fuses and all the connections at the relay board in the engine bay. Actually disconnect them and inspect them closely. Also check all your grounds and make sure they are clean and tight.
There may be a seat belt ignition interrupt under the passenger seat also. You can bypass it buy connecting the two big yellow wires.
betz
Nov 11 2018, 04:45 PM
I got it started!!!
https://photos.app.goo.gl/JbdxmKZtnSXDmpheAI am still clueless about the relays. Jumping the wire at the relay, I get 12V at the plug. Switching relays with another I get no difference, no matter the relay. Removing the relay at the top (closest to the driver seat) now the fuel pump plug jumps up to 10V. Wth? Oh well, f it, that's good enough, time to send itttt!
I confirmed the fuel pump was functioning properly with ignition and cranking. Then I jumped the wire to drain the fuel. Filled fuel connected it back up.. in oh there's a leak at the fuel pump. Probably because the fuel pressure was so high since there was no vacuum. I said screw it and tried to start it... Started on the first try!
I will now take a shower after bathing in fuel earlier. Later I'll muster up the courage to drive the thing! So excited. It sounds like it's running pretty smooth!
Andyrew
Nov 11 2018, 05:09 PM
Awesome! Do a minor tune up and keep driving it! The biggest problem with engine swap cars? They spend most of the time getting bugs worked out while stock motor cars get driven!
The good thing about 914s is you can get the whole thing running on a bench before you swap the motor/trans in. This means you can figure out your fueling, your wiring, the engine itself, shifter, ect then just have a small downtime for mounting and hooking up everything...
Mike Bellis
Nov 11 2018, 08:34 PM
I'm a big advocate of the Audi 20v turbo. I'm a little less HP than Andyrew but that was my goal. reliability over max HP.
Just fixed a limp mode issue at a bad connector on my DBW throttle and I bought an op-amp style throttle booster. It seems to reduce pedal throw quite a bit. Since the car is so light, I leave it on 10% increase.
matthepcat
Nov 11 2018, 09:05 PM
Nice to meet you today betz, will be watching the progress of your build.
Chris914n6
Nov 11 2018, 09:58 PM
QUOTE(Dave_Darling @ Nov 11 2018, 11:35 AM)
QUOTE(Chris914n6 @ Nov 9 2018, 11:07 PM)
I did my Nissan VQ30DE swap back in 2000 before forums existed....
I have heard either this car, or another one with the same engine, running. The engine note is FECKING EERIE!!! Sent chills up my spine. Very cool swap, though not a car I would own.
--DD
Probably WCC'05 in Reno/Tahoe area. Had it WOT up the hill after the candy store stop and several people commented. The 911 stock banana muffler worked out really well in the sound department.
betz
Nov 12 2018, 04:00 PM
I think my next step is to track down this weird issue with idle. When I start it, it seems to idle fairly normal and smoothly. Probably a bit high at like 1500 RPM. I don't know what RPM because the tach is completely dead. Give it gas, and it will hang out at like 3500 or 4000 and hang out there for a few minutes at least. It sounds pretty obnoxious lol.
I took it round the block, drives better than expected. No RPMs, no speedo, and my hood bounced open once.. but the steering feels incredibly light which was surpising as hell. Given no power steering. I did not need to use the throttle because the RPMs were high enough to move the car plenty. It was really the only way to make it shut up a bit actually.
I'm thinking check for vacuum leaks, maybe confirm timing etc. But the rev hang thing has me scratching my head for sure.
Dave_Darling
Nov 12 2018, 04:33 PM
First: FUEL LEAKS BAD!!! Make sure you deal with that; too many of these cars have burned to the ground.
Second: A hanging idle is often caused by timing that is too far advanced. If the centrifugal advance weights stick, which they can do after a few decades, that can cause this. Also having the vacuum dashpot hooked up wrong can do it. Vacuum leaks are another possibility, as they generally cause high idle.
--DD
betz
Nov 12 2018, 08:15 PM
QUOTE(Dave_Darling @ Nov 12 2018, 02:33 PM)
--DD
I mean, the fuel pump only leaked when jumping the wire. Still, I already have the new one and will be putting it in for sure. I'll be looking at the ignition and distributor next.
After driving the 914 I think I might just go a different direction for engine swaps. Super cheap.. but still cool. Subaru Frankenmotor- the 2.5L with 2.2 SOHC heads, give it some nice cams, 3 angle valve job, maybe some mild porting. Good for about 200hp. I can easily buy the engine pieces opportunistically, and save a lot of money. This'll make me feel better about investing towards some fun stuff.. maybe ITB's? :0
I was even thinking of using the EJ251 harness & ECU because it already runs off a MAP...
Nov 12 2018, 08:21 PM
My feeling was to do my suby swap with a cheap but fun engine - SVX, eg33 - $500 for the whole car, get it running, and then play from there. I’m just waiting on assembly.
Andyrew
Nov 12 2018, 09:38 PM
QUOTE(betz @ Nov 12 2018, 06:15 PM)
Peter has that swap, great running car with sensible power.
I've got a video of a drag race between him and when I had a V8 swap. The weight difference and agression off the line for his car meant that he kept up with me to about 60mph when I started to pull on him. I would totally agree with that kind of swap.
The more time behind the wheel of a 914 the better
Tdskip
Nov 13 2018, 07:28 AM
Going down a path that others have plowed is likely to give you a much better result, much quicker.
betz
Nov 15 2018, 03:43 PM
QUOTE(Tdskip @ Nov 13 2018, 05:28 AM)
This is very true. Even partially plowed is better than nothing.
Not going to lie. I'm strongly considering a type 4 build now. Which may or may not be related to the fact that the type 4 may be the absolute easiest motor in existence to fit ITB's to affordably. Looks like they sell 40mm and 48mm throttles for about $550 for all 4. (Why no middle ground??)
Looking into it, I think the big bottleneck for a budget build is the heads. Ideally, I'd want to fit the biggest possible valves into my 1.7 heads as possible and do the whole spark plug relocation thing. I need to talk to some engine builders, I may have a contact with lots of experience with these heads.
If I get the head figured out, seems like the hot ticket will be the 96mm cylinders, 78.4mm crankshaft, and a nice cam to compliment the setup. Wonder if I can pull 6-6.5k RPM out of this motor... what's the limiting factor besides the cam?
From there, I've already decided what I want to do if I go down this path. Megasquirt with ITB's. 100%. I have absolutely 0 experience with carburetors so the whole idea of it being simpler and easier is not the case for me. When I set up the megasquirt with a proper tune I'll never have to worry about it being tempermental and it will run smoother than a carb'd car ever would.
The only thing *not* making me want to build a type 4 is that jerk Jake Raby. Every damn thread about a type 4 build ends up with "you'd be stupid to try this yourself, the only way to have a good motor is to buy it from Jake Raby". And then Jake Raby chiming in "Years and years of R&D, we don't just toss components together, issall in the combooooooooo"
Well, I may have only gotten my degree in mechanical engineering, but if I can toss together a type 4 motor that's 80% as good as a JaKe rAbY motor for a fifth of the cost, then I would consider that a major success.
Is 150 crank hp achievable with this spec?
914_teener
Nov 15 2018, 03:49 PM
QUOTE(betz @ Nov 15 2018, 01:43 PM)
Your personnel comments about someone probably aren't necessary.
Your classes in thermodynamics would tell you what is achievable.
edit:
And the size of your wallet is what is possible.
betz
Nov 15 2018, 04:26 PM
QUOTE(914_teener @ Nov 15 2018, 01:49 PM)
edit:
I didn't need to mention any contacts true.. kind of just thinking out loud that that'll be useful.
My classes in thermodynamics told me that I'd better get the cold reservoir in my engine sub arctic and get that hot reservoir to the surface of the sun and then just garden hose fuel by the gallon and I'll get basically infinite power.
Mechanical engineering courses don't teach jack about building an engine or anything really useful in the real world for that matter, however it does force you to think like an engineer. Whether somebody can apply that to the real world is up to said person. I have built an engine before and that engine got me to work this morning, so I like to think I can apply it well enough.
Realistically I'm not even chasing power else I'd never even consider the type 4. I just want a fun motor. IE, a motor that doesn't feel like you're accelerating with a leaf blower pointed backwards out the window. Other than that.. I'm chasing sound, character, and response. I'm realizing the type 4 may be the ticket to that.
Nov 15 2018, 04:52 PM
QUOTE(betz @ Nov 15 2018, 05:26 PM)
edit:
You just described a small to mid six.
betz
Nov 15 2018, 05:42 PM
QUOTE(mepstein @ Nov 15 2018, 02:52 PM)
I would love an air cooled 6.
Think I could do an air-cooled 6 for under $5k? How about $10k? Yeah. Not gonna happen. Plus I have a perfect little car with a Porsche flat 6 already.
Dave_Darling
Nov 15 2018, 06:27 PM
We know people who run Type IV motors at 7K RPM pretty regularly. Those are race motors, though, and not really suitable for anything but a race car. (Lives in a very narrow power band, gets torn down every weekend, and so on.)
Valve train is one limiting factor for RPM. We have heard of people lightening the stock rocker arms, using high-rate springs, and so on. That helps keeps the valves under control at higher RPMs. So does using lightweight valves and other moving bits (e.g., retainers).
Simply stuffing the largest valves possible into a cylinder head isn't going to be the best you can do. A good cylinder head specialist will work with you on desired power level, RPM range, cam, carbs, exhaust, and so on, and will optimize flow by working the port shapes as well as port and valve sizes. Remember that larger valves are heavier than smaller ones, and require more spring pressure to control.
Lots of stuff can be done. If you know someone who really can do the work well, an honest 150 HP should be very possible.
Note that once you go above ~74mm stroke, one of the rods will start getting perilously close to one of the cam lobes. Double and triple check before you get too deep into it!! Some folks go to reduced base-circle cams for extra clearance. Which works, but seems to be a bit harder on the cam/lifter interface.
Your wallet size will have a very very large effect on how much power you can extract from the motor. And on its durability. Building both of those at the same time can take a lot of work--and therefore a lot of money.
--DD
betz
Nov 26 2018, 06:34 PM
Thanks for the reply Dave.
I just made a black friday order of 914rubber for some houndstooth seats and a loop carpet set! Still working on making the car driveable in the meantime.
Was wondering... Does anyone know about doing a swap with the Subaru / Toyota FA-20 engine found in the FR-S/BRZ/86? I haven't seen a single thread on here where someone has done that. But it seems like an obvious choice to me to someone who wants revs, 200hp N/A, and a nice reliable modern motor. Plus, the FA20 is about to be in it's heyday for aftermarket, as BRZs get more and more affordable. The aftermarket is already quite good. Yeah I mean, they're more pricey motors marginally ($2-3k at first glance), but I'm also working with essentially a brand new high performance motor and won't have to do anything in the way of engine refresh and internal modification.
Doing some searching, it might even bolt up to other subaru transmissions, and therefore work with all of the Subaru swap stuff currently on the market. I'm not sure though. I would wonder if anything engine mount / transmission related is different.
In any case I think this motor would look very right in a 914 engine bay...
rhodyguy
Nov 26 2018, 07:06 PM
wow.
Dave_Darling
Nov 26 2018, 11:18 PM
Well, it sure looks cool! No idea of the answers to your questions about it though.
I'm a bit surprised they're available that cheap; I figured they were still too new to have many available from wreckers. Much like the 718 motors. (Which could make for an interesting all-Porsche swap!)
--DD
Larmo63
Nov 27 2018, 12:22 AM
I'd call Jake Raby and get his opinion.
betz
Nov 27 2018, 11:17 AM
QUOTE(Dave_Darling @ Nov 26 2018, 09:18 PM)
--DD
You're right, couldn't find a single 718 motor on car-part. But the FR-S and BRZ has been available since 2012! And it's only a $25-30k car new. Plenty of time for people to crash it. The new BRZ and Toyota 86 with a stunning 205hp don't have many engines available though. My friend has a 2018 and I can attest the difference in hp is not noticed and the torque dip is still present. The tighter gearing is nice though.
There's actually a 31k mile motor available 5 miles from me in San Jose for $2200. It's pretty tempting. But I think if I went through with this, I'd need the engine, wiring harness and ECU at a minimum. Would be nice to find a car that's being freshly parted out.
Chris914n6
Nov 27 2018, 03:15 PM
The 86 is like the 350z... the enthusiasts are doing motor mods and blowing them faster than cars get wrecked. Prices are going to be high for a long time.
betz
Nov 27 2018, 03:39 PM
QUOTE(Chris914n6 @ Nov 27 2018, 01:15 PM)
I don't think that's totally true for the 350Z. The insurance rates are super high on that car for a reason. It was named the most deadly car in 2011. They get crashed a lot and I'm sure you can get a VQ motor for super cheap.
$2200 is not a lot for a motor with 30k miles. It's actually kind of a bargain. Really a bargain when you consider it's a 100hp/L motor. Here in CA you're not even allowed to modify the motor. The most people do is a cold air intake and exhaust. If people are turboing they are also doing motor swaps. Shoot, there's that one out there with a Ferrari 458 motor.
There are easily more crashed cars than turbod cars that blow up. The prices will continue to go down as the motor gets older. All of this is moot though because I can totally afford one right now if I wanted it. It will cost me less to buy this than it would be to buy an old tired subie motor and refresh it.
The question is.. will it be a relatively easy swap?
1adam12
Nov 27 2018, 04:30 PM
I originally thought of doing an FA-20 swap a year ago when I purchased my 914 but ultimately decided to keep it air cooled. I even discussed it to the shop that built the Super Street FRS SEMA build with ITB set up. They said it was an absolute headache as they had to customize everything as expected and the tune was difficult with the ITB set up.
betz
Nov 27 2018, 05:27 PM
QUOTE(1adam12 @ Nov 27 2018, 02:30 PM)
I mean that's to be expected, not only converting it to ITBs but converting a motor designed with direct injection in mind for port injection. Did they have any insight on putting one in a 914?
1adam12
Nov 27 2018, 06:05 PM
QUOTE(betz @ Nov 27 2018, 03:27 PM)
At the time I only discussed with them regarding the engine build. I didn't even go into fabrication needed and installing it since I changed my plans.
Chi-town
Nov 27 2018, 06:58 PM
FA20 is a joke. Underpowered, unreliable when used hard, and a small fortune to build correctly. Oh and still no reliable upgrade for the oil pump in the front cover of other than dry sumping it.
And don't get me started on the DIT version
Mike Bellis
Nov 27 2018, 07:16 PM
Jake is a Marine and we have a very low bull shit tolerance. I actually love it when he rants. It reminds me of the good ole days... Semper Fi
He is the best when it comes to the T4 engine but there are others that are also very good. HAM makes the best head modifications. You can now buy much of Raby's tech at the T4 Store and get on the waiting list for HAM to do your heads. Be prepared to buy new heads when HAM rejects them. Making good reliable HP in a T4 is not cheap. Main bearings can be hard to source. For the price of a good T4, you could drop a SBC with adapter kit and have money left for gas...
betz
Nov 28 2018, 12:45 AM
QUOTE(Chi-town @ Nov 27 2018, 04:58 PM)
The point of this motor is that I won't be building it. I want 200hp specifically.
It would be hard for me to believe an EJ253 is a better motor in any way compared to an FA. Not to mention the FA is light weight and is even shorter than the standard H4 motors, bringing the center of gravity way down.
So considering use on a mostly street car, I don't see how it would be a bad option, unless I want something to bounce off the limiter continuously. Then sure, I'd probably want a K20. And in that case I probably wouldn't mind cutting up my trunk as much when having to make it fit.
Chi-town
Nov 28 2018, 12:56 AM
The EJ series engines even N/A are cheap and easy to make power with and plenty of parts to do so. I've gotten 200hp out of an EJ251 but not without a build and aftermarket ECU.
The K series is still the #1 bang for the buck.
If I build a second car it'll probably be a K24 or F22
betz
Apr 23 2019, 04:32 PM
Welp, after a half a year of deliberation I've come full circle back to the 4A-GE blacktop.
I found a mint one for about $1200, aka, for less than a K motor, fully dressed with wiring harness ECU etc and about 60k miles. Here it is:
Reasons I chose it over the K motor?
ITB's. I'm sorry but I am a total sap for ITB's. I looked into ITB's on a K motor, It would be over triple the cost and way too much power for my little 914. I want to keep it at max 200 hp. Fitting it to a "regular" 4A-GE requires an adapter but would definitely be cheaper than the K. But I would still need to run an aftermarket ECU. I want this project to be, once the motor is running, it's running perfect. Tuning can be a total headache and expensive. Also, packaging wise, the ITB's coming out the side works super well in the rectangular 914 engine bay.
Size. Dimension wise, the little 1.6L 4A is smaller in every dimension. Online I found it was 21" from bottom of oil pan to top of valve cover. That's shorter than an EJ. the K motor is around 26". Barely will clear the engine cover.
Vision. I have an, erm... theme, in mind for my 914 once it's done. I will be embracing my little Toyota motor, I'll leave it at that
I appreciate everyone's advice and I considered everything about this build but in the end I must follow my heart on this one or else I won't even have any motivation.
New direction also, I will be starting with the engine first, so I don't get the car looking all pretty just to cut it up again.
I plan on starting a build thread once I have some stuff to post, so stay tuned!
rhodyguy
Apr 24 2019, 12:42 PM
What is the timing belt interval for that engine? I'd put one in before the install and forget about it.
Chi-town
Apr 24 2019, 04:43 PM
That's not a mint one, that's your standard JDM importer spraying the whole thing down with clear coat. If that's where you got it there's no way it has 60k on it unless you got the front clip with the odometer to prove it. Most of those engines come out of 100k+ cars.
Contact Grant at Battle Garage for all the stuff you'll need to replace on it. He knows his 20v and stocks most of the hard to get parts.
betz
Apr 24 2019, 05:26 PM
QUOTE(Chi-town @ Apr 24 2019, 03:43 PM)
Eh, maybe, clear coating seems unnecessary shady though. He did show me a pic of the engine just when it was crammed with all the other engines and it still looked pretty good although dustier. I don't see how they could get rid of all the oil spots and make it looks so nice just with clear coat. I feel like he just wiped it down with armor all or something but I was more looking at where all the gaskets meet and in all the crevasses where you would see some real problems that simple green wouldn't solve. As it stands I'll probably replace anything that's sensible to replace like the belts and
probably timing belt and water pump gasket etc.
In any case I've conceded this car is very far from a daily driver and I am putting what is still a Toyota engine into it. I'm not really too concerned.
Thank you for the source for parts though, another reason I became less scared of this motor was that the aftermarket seems quite good and you can still find parts at reasonable prices even though it's a JDM motor. Also a lot of US 4A GE parts seem compatible or 4A FE so as long as you're a little resourceful it shouldn't be too bad to get stuff for it.
RolinkHaus
Apr 24 2019, 05:50 PM
How about a German engine??
Chris914n6
Apr 24 2019, 06:02 PM
You want to do all the usual maintenance items before the install. All the rubber will age out at 10 years, including the timing belt. Crank seal and specially the rear main. Water pump & pulleys are unknowns at this point. Do you really want to possibly drop the motor in a few months to save 100$ today?
Also pop the valve cover & oil pan to look for sludge & other signs of issues.
Don't let the cleanliness fool you, something has been leaking....
betz
Apr 24 2019, 07:13 PM
QUOTE(RolinkHaus @ Apr 24 2019, 04:50 PM)
German engines aren't missing from my life. Individual throttles are, haha. I did consider megasquirting a Type IV and running individual throttles, but then I'd really need to build the type IV and I really don't want to go down the engine building rabbit hole again. No interest in the VW 1.8T. Price of the flat 6 kills any interest. A VR6 would be okay but I already have my BMW I6. If someone gave me a free S14... Yeah no I'd just put it in my E30, lol.
QUOTE(Chris914n6 @ Apr 24 2019, 05:02 PM)
Of course I'm popping open the valve cover, to see those glorious 5V / cylinder! Haha.
I definitely plan on refreshing the engine while it's on a stand and everything is easy to get to, though. Crossing my fingers everything looks clean and well maintained..
2mAn
May 14 2019, 04:38 PM
QUOTE(betz @ Nov 6 2018, 05:19 PM)
Thanks for all of the welcomes! I hardly got that on r3vlimited, haha.
QUOTE(betz @ Nov 15 2018, 03:26 PM)
my thermodynamics class was about the time all of my daydreaming finally told me I was in the wrong major... 15 years later I graduated with a BS degree haha
QUOTE(Larmo63 @ Nov 26 2018, 11:22 PM)
so, Ben have you driven it yet?..
Bleyseng
May 15 2019, 07:35 AM
QUOTE(betz @ Nov 8 2018, 05:54 PM)
QUOTE(Andyrew @ Nov 8 2018, 03:12 PM)
Lots of 914 guys around you... Why dont you go for a ride in a few different cars? I'll have mine on the road in a couple months and your welcome to feel a laggy 500hp big turbo 4 motor. Mueller should be getting his on the road shortly after he finishes his small to do list (BUILD DAY?????) and thats a Honda v6 motor..
Honestly I wouldnt bother putting any motor in a 914 that didnt at least have 200hp that wasnt a type 4 or 911 motor...
100hp feels pretty slow. 140hp feels quick, 180hp feels Plenty quick. But that 200hp mark is where things really start to get FUN. Below that just about any modern car on the street will be faster..
I would absolutely love to check out some other 914's!
Don't get me wrong, I will be powing around in that type 4 for some time before I get down into a swap. I have not done all my research on built type 4's, but it seems like everyone recommends that Jake Raby kit which is like $9k. I get that it's an all in one kit, but seriously? That's some serious dough.
As far as horsepower goes, I don't know if I totally agree even when talking swaps. I much more heavily consider the character and feeling the motor gives you over pretty much anything else. I'm not going to race it, at least not for serious competition. It's entirely for fun. That's why the 4AGE sounded better to me than a K series. Shoot I almost want to put a Busso V6 in the thing. But obviously I have to consider having an actual realizable goal.
QUOTE(Dave_Darling @ Nov 8 2018, 03:35 PM)
Oh, and any time you're doing the first swap of motor X into a 914, you will want to measure and measure and measure and measure. Some engines that would seem to be natural for swaps (928 V8 engines, 944 engines, some others, even four-bangers) actually do not fit without some fairly significant mods. The firewall on the 914 tilts back at a noticeable angle, and that can cause fitment problems for taller engines. The firewall can be moved, the whole drivetrain can be shifted aft in the car, and other things can be done, but you will definitely want to figure out if any of those are needed first.
--DD
I will definitely keep this in mind. Yet another reason I should choose a domestic motor. So I can go down to a local dismantler and take a bunch of measurements before I make any rash decisions.
For a built type 4 just buy the Raby cam 9990 kit, Len's 2.0L AA heads w/44/38 valves, 96mm pistons and use 2.0L Djet or 44 Webers. That's 125-130 hp for about $4-5K. You can rev it to 6500rpms and tons of lightweight HP plus it's plenty streetable for just driving the damn thing around. Then you have money to spend on the suspension, paint, interior etc
Grego in Sac
Jul 15 2021, 01:30 PM
QUOTE(betz @ Apr 24 2019, 08:13 PM)
I’m a sucker for ITB’s too and kinda glad you went this (kept) direction!
Wondering if you had any progress
