bd1308
Jun 18 2005, 10:44 AM
is not to stab them with a screwdriver....got any other methods?
scotty914
Jun 18 2005, 10:58 AM
go get a coat hanger or other stiff wire. cut it off and bend a hook that is small, like 1/4 inch. then stick it in the exhaust port and hook it on the back side of the cooper ring and pull.
you may have to rebend and pull from multible spots
when you go to put new ones in hang them on the coat hanger and heat them with a propane torch till they real hot and then drop them in to water. this will soften them up they they seal easier
Mueller
Jun 18 2005, 12:07 PM
I bent an old screwdriver...works great
bd1308
Jun 18 2005, 01:08 PM
QUOTE (scott thacher @ Jun 18 2005, 10:58 AM) |
when you go to put new ones in hang them on the coat hanger and heat them with a propane torch till they real hot and then drop them in to water. this will soften them up they they seal easier |
quench the copper?.......from what i recall that repairs stress cracks on a molecular level....quenching it makes the grain boundaries smaller and therefore makes the metal more brittle....
just working out the logic in my mind.
scotty914
Jun 18 2005, 01:16 PM
QUOTE (bd1308 @ Jun 18 2005, 11:08 AM) |
just working out the logic in my mind. |
in steel yes quenching it makes it harder and a slow cool softens
copper or other non ferious metals slow cooling hardens and quenching softens. if you want go get a 50 cent copper fitting and try it, you can get a copper plumbing fitting almost soft enough to squeeze by hand
bd1308
Jun 18 2005, 01:37 PM
i remember it now, yeah i was able to wrap a huge copper length of tube in tiny concentric circles.......after quenching that is
Tom Perso
Jun 18 2005, 01:39 PM
WTF are you doing that requires being copper tubing in small circles???
Tom
bd1308
Jun 18 2005, 01:42 PM
its called a lab....
at least i was doing SOMETHING with it...other people just heated it up and branded thier lab partner.
scotty b
Jun 18 2005, 03:08 PM
QUOTE (bd1308 @ Jun 18 2005, 11:42 AM) |
at least i was doing SOMETHING with it...other people just heated it up and branded thier lab partner. |
A LAB? and you were doing soMETHing. 2+2=
rhodyguy
Jun 18 2005, 03:12 PM
i bet shine.
k
scotty914
Jun 18 2005, 03:14 PM
he is in KY
scotty b
Jun 18 2005, 03:16 PM
rolling meth lab would explain ALOT
bd1308
Jun 18 2005, 06:21 PM
actually meth labs are real big in Indiana....nobody can get asprin of any kind w/o a perscription and a quota of how much can be bought.
the lab I was in was explaining the difference between cquenching and not quenching in various materials....
