QUOTE(914forme @ Nov 10 2018, 11:55 AM)
@tornik550 Want to sell the engine run stand? Or point me in the direction of pictures.
Unfortunately I chopped it up when I was done cause it took up took much space. It was pretty easy to build. I have almost no experience with metal fab. I only had a cheap harbor freight flux core welder. It worked very well however the two things that I would change are instead of theee wheels, I would have used four. If there were two wheels under the transmission it would have been more stable. I didn’t have issues with stability however it could have been a problem. I would have also used larger wheels. Even with the handle I put on, it was somewhat hard to push. If I remember correctly, the only problem I ran into was the oil tank height.
I also purchased the cheapest gauges I could find along with some sort of a lawn mower throttle.
