Got some extended time to work on the car this weekend and installed a PLX wideband AFR.
I got the bluetooth version that displays the readouts on their smartphone app.
Welded the O2 bung in to my Bursch exhaust (this is after a lot of grinding to clean up my sloppy welds).
After some high-temp paint to guard from rust, the muffler and O2 sensor is installed.
A screenshot of the app up and running and ready for tuning.
It was all very easy to install. I routed the connection from the O2 sensor up through the firewall along side the spedo cable. Installed the PLX head unit behind the center console out of sight. Got power for the head unit from an open 12v spade on the fusebox that is only on when the ignition is in the 'on' position. (I gave up on trying to get to the cigarette lighter for power pretty quickly as there's not enough space in there for my hands.)
Bought this setup to tune the engine after installing a rebuilt MPS that now has my car way out of tune. Hope that futzing with the MPS is as easy as it was to install the PLX.
