partwerks
Nov 13 2018, 09:00 PM
When locking the driver's side door, and holding the flap to close the door, it just bounces back and doesn't lock, and so wondering where the problem is?
Chi-town
Nov 13 2018, 09:13 PM
I thought you had to close door, lock with key?
partwerks
Nov 13 2018, 09:22 PM
PS you always had to lock it, and slam the door shut. End of story, but as I recall the DS you locked it, and then held the flap till it closed, but in this case the body shop must have botched something up?
seanery
Nov 13 2018, 09:39 PM
hmm, i thought it was always with a key, too
sb914
Nov 13 2018, 09:41 PM
Check the door jam receiver part. Sometimes the lever is in wrong position.
Used to happen to my vw bug.
sb914
Nov 13 2018, 09:43 PM
And You don't need key to lock door !
TheCabinetmaker
Nov 14 2018, 09:03 AM
Seriously guys?
You must lock the drivers door with a key. It's not broke! It's made that way, so you don't lock your keys in the car!!
sb914
Nov 14 2018, 09:14 AM
QUOTE(TheCabinetmaker @ Nov 14 2018, 07:03 AM)
Seriously guys?
Really ? Go try it. I lock my door Without key every time.
76-914
Nov 14 2018, 09:23 AM
The psg door will lock w/o holding the handle but the driver will lock w/o the key. My 76, 73 & 70 do anyways!
sb914
Nov 14 2018, 09:24 AM
Thanks Kent !
Steve
Nov 14 2018, 09:28 AM
QUOTE(76-914 @ Nov 14 2018, 07:23 AM)
Same with my 75 and previous 73.
Try it...... I've owned 914's since the late 70's and they've always worked this way.
sb914
Nov 14 2018, 09:31 AM
Seriously guys?
I taught a old dog a new trick.
sb914
Nov 15 2018, 08:47 AM
QUOTE(partwerks @ Nov 13 2018, 07:00 PM)
Here's the pic per your pm. You want the lever in this position.
dr914@autoatlanta.com
Nov 15 2018, 09:06 AM
the catching mechanism is dirty, you will have to remove it and clean. It is getting stuck midway between open and locked that is what is doing it. An easy repair once you remove the door panel
QUOTE(partwerks @ Nov 13 2018, 08:00 PM)
partwerks
Nov 15 2018, 09:12 PM
It is in that position. I was also told by a second person it might just need cleaned.
