Bob Wolcott
Jun 18 2005, 03:48 PM
Is there a special tool required for removing the small rubber seals that seal the valve step at the top of the valve guide? What is the best procedure for this?
Thanks,
Bob
type47
Jun 18 2005, 08:44 PM
??? wow, i must have missed that one, are there rubber seals? there is a valve removing tool/jig to allow one to remove the springs. there are split keepers at the top of the valve stem and the jig compresses the spring to allow the keepers to be removed.
are you talking about type IV?
Bob Wolcott
Jun 18 2005, 10:00 PM
It is an early 911 head and it looks like the seal is retained by a collar or something. Here is a picture
http://oregonstate.edu/~wolcottr/Porsche/H...ad/DSCF0005.JPGBob
ejm
Jun 19 2005, 05:18 AM
The seal and metal ring is one piece and just pressed onto the guide. I've seen special removal tools but you can just carefully pry them off. To install new ones you'll need a drift something like this.
TimT
Jun 19 2005, 07:31 AM
Yes you can just pry them off woth a screwdriver, yo install use a 13mm socket and extension and tap them on.
The seal pictured is the old style seal, a bakelite sleeve w/oring. The new style is teflon. There is debate which is the better seal, some claim the teflon doenst allow enough oil to the valve stems.
I have used the teflon style on my engines, annd the seem to work fine. The teflon seal will not be included in a typical gasket kit. If you decide to go with the newer tech teflon seals you will need to purchase them seperately.
Bob Wolcott
Jun 19 2005, 09:24 AM
Are these seals something that can be reused? I want to remove them when I clean the heads but they all appear to be in good condition.
Bob
