Hey!
I’m finally getting around to fixing my 74 914 and I am having a problem with my headlights. They don’t work. When I pull the high beam switch on the steering wheel the lights momentarily come on. when I release the switch they go off. I crunched my right front fender which probably shorted out the lights and this is I think where the problem started. I fixed the fender and replaced the lights they all work except the headlights. If you have any opinion on how I should go about fixing my lights I would really appreciate your help. I suspect that the high beam low beam turn signal switch and/or the relay foot fryer during the crunch. I have other problems that I will be diving into after I get this one solved.
