********UPDATE*********
Fixed all of the leaks, the grommets are in as far as I believe they will go. Re-bled the system. No bubbles, went around twice. Hooked up the emergency brakes, tight, tight, tight! Put the tires on and drove the car down the street and back.
First time the car has moved on it's own power since '84.
TWO OBSERVATIONS - any comments or direction are appreciated.
1. Rear brakes are too tight (dragging) so I need to adjust "venting clearance" ? Correct?
2. Brake pedal travels half-way on the first push, high and tight on the second. Need guidance here - what should I look at first?
Thank you all 914W gurus.
CTC911CTC
QUOTE(ctc911ctc @ Nov 16 2018, 02:28 PM)
My 17yr old son and I replaced the MC with a new one last week - since it was VERY cold here in New England we may have not taken the care the job deserved. Once installed I noticed that there was leaking from the reservoir hoses, the grommets seemed to have pulled loose.
