Hello Everyone, Just picked up a 1973 yellow 914 the other night. Short story, previous owner had bought it a couple years back, drove it on and off, and was working on restoring the car.
Outside looks very nice. Paint is in good condition. He had the targa top, rocker panels, bumpers, and rims all refinished. New weather stripping everywhere execpt the front targa seal. He had pulled the interior and started putting it back when he had to sell the car.
Interior has the seats (driver side is brand new), dashboard, and that's pretty much it. The gauges have been redone and look absolutely beautiful, however the speedo sticks at zero sometimes. If you tap it, it will move to where it should be. He said the person who redid the gauges put too much grease on it?
Engine, runs well, but he said a previous owner removed the cold start valve so it is rough at idle and starting when it is cold. After a minute or 2, it's good. Still running the original EFI, which was also cleaned about 2 years ago. New stainless steel fuel lines (no more plastic!). Transmission and clutch feel good. He checked linkage bushings in the last 2 years, and they all look good. Some oil/gunk buildup on the underside. Possibly a leaky oil cooler seal? No visible oil dripping from the underside, or puddles under the car, which is good. Very little rust as well. Small rust whole in the battery tray (top section), but no where else. Just put in new water drain lines this morning for the engine cover.
Lots of extra parts. The original driver seat. A second set of bumpers. Second set of suspension parts. Almost all new interior pieces and carpet just needing to be installed.
On to questions.
1. He gave me a part that he said was the cold start valve (see picture). Is that the correct part, and if so, where does it go?
2. Storing the targa top in the trunk. What way does it go? I'm having trouble getting it to fit and close the trunk all the way.
3. Speedometer gauge. Would too much grease cause the problem I described? How easy would that be to fix?
Those are the questions jumping to mind currently. Thanks everyone! Look forward to joining in conversations about these fun little cars.
