All,
The brake build is over, new from the reservoir to the rotors.
Rotors
Pads
Calipers (PMB thanks!)
Lines
Master Cylinder (19MM)
Rebuilt pedal assembly
Found 2 leaky bleed valves, needed a little more torque to seat properly.
Went around the car 4 times in pursuit of bubbles, used almost a gallon of Brake Fluid. Did both the top and bottom bleed valves at each caliper (bottom first, then top - air rises, right?).
Brakes work (back is a little tight, need to adjust the calipers) however the pedal is not right. First press it travels 2-3 inches before there is the familiar FIRM feeling, second press the pedal travels less that an inch before contact.
OK, I am out of ideas,
WHAT WOULD YOU DO NEXT?????
Thank you in advance all 914worldies
CTC
