QUOTE(Tdskip @ Nov 26 2018, 11:34 AM)
QUOTE(dr914@autoatlanta.com @ Nov 26 2018, 02:27 PM)
check the clutch tube, when it breaks loose from its bracket up front, it blocks out fourth fifth gear. (assuming that the shifter is in adjustment and the bushings are all good as you say
Good morning - thanks for the follow up.
Mine was actually loose and you could see where it was hitting. I made a bracket to make sure it wasn't flopping around and secured it so I have full movement now.
I think (make that HOPE) I just messed up the adjustment procedure.
Thanks again and great tip.
TDSkip,
I want to point out something. My 6 number 41 had a bad clutch tube when I bought it. The PO or some PO put a U clamp with 2 small drilled holes in the center channel on the left side of it. It was placed at the front of the tube with threated parts going through on drivers’ side and then they put 2 nuts and ground down the extra threads. They also did it on the bottom. It is hard to pull pictures of this but I have them at work.
I guess it worked for them but I fixed the full tube the right way with extra welds.
This could hold you over for some time with not that much work.
If you want to go over this with me we can call each other on it. You can also find some postings on this in world as well as posting on it from me. Or I was in on a thread on it.
Regards,
Bob B
