Subaru Engine Mount.
These are better photos of the engine mounting system. It mounts the engine (unlike a cradle) it
does not restrict the side of the engine where space is needed for exhaust, turbo, etc.
It also allows the transaxle to be removed without removing the engine. The engine can be moved forward or back , depending on where the mounting brackets are welded to the chassis.
It provides a very strong mount. It handled the 2.7L 600 HP and 500 ft-lbs torque. The crankshaft spacer is required to adjust for the 1/2" thick motor plate from Kennedy Engineering.
$1,250.00
[size=4]
[size=4]Click to view attachment Click to view attachmentClick to view attachment
