tvdinnerbythepool
Nov 26 2018, 06:29 PM
Hey guys,
Going to rebuild my pedal cluster, and at the point of disconnecting the clutch cable at the clevis by the cluster.
Should I loosen or disconnect the cable at the trans before disconnecting up front?
Thx!
Chris914n6
Nov 26 2018, 07:45 PM
It's usually under a bit of tension, so yes, loosen the trans side first.
I like to fasten a twist tie as a marker to get it back in the same spot.
