I am chasing down a vacuum leak.
I replaced a worn late throttle body with a NOS early throttle body.
A throttle body rebuild post I came across shows a brass ring seal and a seal that goes around the shaft on the end where it enters o the throttle body.
Neither of the TBs I have have the brass ring or the seal.
Are there supposed to be a ring & seal on each side of the TB? Are these available? Are they necessary? Are they the cause of my vacuum leak? I can't detect any play in the shaft.
Picture I found that shows the brass ring
Pic of a post I found that shows all the parts:
