Rear toe adjuster.
Absolutely the best way to adjust the rear toe and keep it from going out of adjustment.
To adjust the rear toe, without the adjustable link, you pull the wheel in or out with bar and try to hold the wheel in place while you tighten the three nuts to hold it in place.
With the adjuster, you set the toe using the link and lock it in place with the allen screw and three nuts. So easy, the toe can be adjusted at the track. $250.00
Click to view attachment Click to view attachment
