QUOTE(TheCabinetmaker @ Dec 3 2018, 05:36 PM)
Hmm, dpr website says they are reground from vw oem cranks, and they are all . 010-.020 undersize. I think that is a stock crank, yes?
Well, I talked to DPR and they said the 2.0 cranks are offset ground from 1.7/1.8 cranks. He did say you’d have to order the correct .010-.010, .020-.020 bearings.
QUOTE(Dave_Darling @ Dec 3 2018, 07:53 PM)
Offset-ground cranks mean you need new rods with smaller big-ends. I don't know how much those will cost you, but I bet they won't be free.
Might be better to pick up a 2.0 crank and rods together if you are going that route. Depends on what deals you can find, I suppose! Also note that 2-liter Bus crank and rods will work, as they are they same size as the 914 bits.
--DD
According to the person I talked to at DPR, their offset ground 2.0 crank uses 2.0 rods, with first or second cut bearing accommodation. Makes me think they must be welding on material to the journals.
Good to know about the bus crank and rods. One thing I haven’t seen yet in this thread is someone saying “I have a good 2.0 crank and rods that I’ll sell for $xxx. Would be interested to know the current value (perceived and actual!) of these parts. Back to my Pinot Noir.
