QUOTE(barefoot @ Dec 14 2018, 09:41 AM)
Easier way:
Calculate the spring rate from a few dimensions you can make, then use the link:
https://www.acxesspring.com/english/compres...lculations.htmlI measured my spare set (assembled), so free length is a guess, but spring rate not affected.
Wire diameter = .387"
Coil OD = 4.1"
Number of coils = 10
Free length = 15
That yielded a rate of 62 Lb/inch
I just used the calculator for my set of unknown springs and a set of Weltmeister SP100 100 lbs springs.
Specs unknown springs from the late 80's/early 90's bought at AA IIRC.
Wire diameter = .475"
Coil OD = 4.125"
Number active of coils = 9
Free length = 12.5"
= 160 lbs (159.5)
Specs Weltmeister SP100 (100 lbs), springs are about 4 years old.
Wire diameter = .425"
Coil OD = 4.250"
Number active of coils = 7
Free length = 15"
= 120 lbs (119.64 lbs)
So either the calculator is wrong or Weltmeister SP100 advertised as 100 lbs are actually 120 lbs springs.
My unknown springs 160 lbs sounds about right.
