dazpugh
Dec 14 2018, 05:37 AM
Hi all,
Does anyone know the measurement from hub to hub on a Gt? I have a GT clone with steel arches and spacers on the front but want to know the original width of the track.
Cheers
ConeDodger
Dec 14 2018, 07:07 AM
The same as a 914-6
TravisNeff
Dec 14 2018, 07:38 AM
I think it is the same track width as stock
dazpugh
Dec 14 2018, 03:44 PM
QUOTE(TravisNeff @ Dec 14 2018, 06:38 AM)
so they both used spacers bolted to the hub?
mb911
Dec 14 2018, 03:48 PM
I wondered the same thing as I running 7 and 8s and from the looks of it 8s and 9s would be an easy fit..
TravisNeff
Dec 14 2018, 03:50 PM
I think they came with 15x6 wheels and no spacers. It was up to the customers to change it up I believe.
dazpugh
Dec 15 2018, 03:03 AM
i ask the question as i see cars with GT arches that are really low at the front whereas if i drop mine at the front the tyre catches the arch on full lock if i hit a bump.What size spacers are you guys using?
Dec 15 2018, 06:19 AM
QUOTE(dazpugh @ Dec 15 2018, 04:03 AM)
Tires have different profiles. Elephant has some stops to keep it from hitting at full lock but that's just the way some cars are. Spacers might help, a lot of guys run 944 turbo (24mm) spacers on the front.
JFJ914
Dec 15 2018, 10:45 AM
QUOTE(dazpugh @ Dec 14 2018, 04:44 PM)
They had 21mm spacers.
Steve
Dec 15 2018, 10:54 AM
QUOTE(mb911 @ Dec 14 2018, 01:48 PM)
I’m running 8’s and 9’s with AA GT flairs. No problems.
sixnotfour
Dec 15 2018, 01:14 PM
depends on tire size and how flairs where installed,,if this is your 914 ,
looks like you need to remove the spacer.. to go lower, and turn
sixnotfour
Dec 15 2018, 01:19 PM
my 914 with 15x8 /9s 225/50 frnt 245/50 rears ,, good ole tires
sixnotfour
Dec 15 2018, 01:48 PM
I have early front hubs rotors, yours are prob. Carrera wich is a bit wider hub,, increasing track width
Dec 15 2018, 02:04 PM
QUOTE(ConeDodger @ Dec 14 2018, 05:07 AM)
The same as a 914-6
The factory GTs usually ran 7"/9" wheels with spacers ...
sixnotfour
Dec 15 2018, 09:27 PM
true ,, but ..not a factory GT..
Dec 15 2018, 09:47 PM
QUOTE(sixnotfour @ Dec 15 2018, 07:27 PM)
I have no idea what ,, or ..who your comment is aimed at..
sixnotfour
Dec 15 2018, 10:12 PM
the OG poster,,his post is misleading apples and oranges
ClayPerrine
Dec 15 2018, 10:15 PM
If you use 944 turbo wheels (951 part number), you don't need any spacers. The offset is correct for the 914-6.
sixnotfour
Dec 15 2018, 10:57 PM
951,,911 x7 same offset,unless your referencing 8's
the silver pic is his 914-6 GT Clone
dazpugh
Dec 16 2018, 01:48 PM
That is my car.
I will try removing the spacers but will that give me a problem with hitting the inner arch on full lock.
Thanks for all the input
mb911
Dec 16 2018, 02:33 PM
QUOTE(dazpugh @ Dec 16 2018, 11:48 AM)
That is my car.
No should not.
