This is for a 2.0 L D-Jet
The pump I am trying is a rebuilt unit that I had around for a year. I am replacing the original unit because it was not producing any pressure in the fuel rails. The pump came on when you turn the key. I went through the entire fuel line system with new hoses. I do not have any crimping in the lines. I thought I would try and see if the rebuilt one was good before I switched it out
I mocked up 1 fuel line to a gas can. That line is hooked up to "s" port on the fuel pump.
I hooked up the next fuel line to the "d" port and ran it to an empty gas can. The final port "r" was left open. What I expected to happen was that the "d" port would push gas into the empty gas can. What I got was the "s" port sucked up the gas in the full gas can, the "d" port didn't push out anything, and the "r" port started to push out gas. The gas coming out of the "r" port wasn't forceful like I thought the "d" port would be but had some air with the gas.
Why isn't the "d" port pushing out gas? Do I have to connect a fuel line to the "r" port
to get the pump to function so that the "d" port pushes out fuel? The "d" port is meant to hook up to the rear of the passenger side fuel rail.
The way it is set up is that the "s" port is on the top. The "d" port is in the middle, and the "r" port is on the bottom closest to the power connection.
Thanks,
Buck
