QUOTE(JeffBowlsby @ Dec 27 2018, 07:42 AM)
No, not interchangeable.
For 914 2.0L's there are two different MPS's, and their PNs end in 037 (1973-only), and 043 (1974-76). These are physically the same internally but are calibrated differently for compatibility with their respective ECU's, which are also different.
The 914 1.7L has a single MPS, PN ending in 049. It is physically different internally and calibrated differently, from the 2.0L MPS's for compatibility with the 1.7L ECU's.
Jeff, how do us guys with 1911 motors deal with the 049 MPS issue? I have an Innovate LM-2 AFR meter, so that
should help with the adjustment?
I plan to keep the 1.7L FI components but use green 2.0L injectors. I also have a set of 1.8L injectors, but think the 2.0L will be closer than those.
