Many moons ago LN did a bunch of birals, but found the cost for a set of done to their standard to be only a couple of Benjamins less than Nickies. The issue is casting, the two metals have way different expansion rates. Poorly made this causes the alunimum to separate from the iron, thus creating a hotspot(s).
On top of this they found the increase in cooling to be marginal at best over a bored out T4 iron cylinder and no competition to the aluminum cylinder.
This is basically the same thing Porsche found with the 911 engine. As the HP #'s went up they tried birals (à la 356), but within a relatively short period had to introduce alunimum cylinders.
Are the T4 birals available any good? Hard to say, honestly I haven't used them or heard of anyone with enough miles on them to give a honest verdict. Made in China, AA had quality issues at first, but I think they're getting better at QC.
On a 2270 or 2056, I'd spend the extra coin on better valve train, heads, balancing, etc. I personally don't think Nickies are warranted on T4 till you get into stroker performance engines or higher RPM for racing. The 2270/2.3 96mm is a goldilocks zone where both iron and Nickies work well, but you do definitely run cooler head temps with Nickies.
BTW I'm a LN dealer.
