Yes, the original struts didn't have inserts. The stut housing was the shock body and to install an insert you would remove all the pieces and the oil. We usually left a few ounces of oil in the strut to help carry heat from the insert to the strut body to be dissipated to the air.
The original shock oil is foul smelling stuff.
Jim
Jan 2 2019, 07:00 AM
You got the insert out. Nowadays, Billstein says no oil in strut housing.
Mueller
Jan 2 2019, 01:21 PM
Thanks, I figured out that I have the Boge struts.
I was expecting self contained inserts like my other 914s in the past.
Will Bilsteins fit in these?
Jan 2 2019, 01:44 PM
QUOTE(Mueller @ Jan 2 2019, 02:21 PM)
Yes. Billstein makes inserts to fit Boge 3 1/2. They work great. They come with a new threaded top pieces. Both inner and outer threads. You use the ones that fit your struts and drop the set you don’t need in a drawer.
Mueller
Jan 2 2019, 02:02 PM
QUOTE(mepstein @ Jan 2 2019, 11:44 AM)
Thanks, now spend some of the money I got from selling my 1.8 motor
