Hi All,
The turn signal (or as we say indicator) switch on my car is packing up (very 'rough/notchy' when moved), and i need someone to look at it (assuming it's economical to repair).
There are no direct replacements for a -6 switch so i'm wondering if anyone can advise on the following options:
1) Will a 911 switch from the same period (1970) make a direct replacement (is the wiring harness connections the same ? I know the indicator arm has a different number)
or
2) Will a VW part work?
or
3) Can anyone advise if someone in the US can repair these?
Thanks
Chris
