Thanks guys. Looks like we are making progress but these parts are a little confusing. I already bought the wrong brake hardware from another member so I'll try to avoid repeating that. I also forgot I also need a trunk hinge stay so added it to my original post. So here's some follow up.
@KevinW - Looks like this checks off 6 & 7 from my list but can you verify the rubber springs are from the rears? The PET shows different part #s for front and rear and yours look a lot like my fronts so I want to double check. Part # for rears should be 914 333 053 01.
I have the eye bolt piece that is on the pedal end of yours so you can keep it for a rainy day if you like. I'm pretty sure I have the whole assembly somewhere but dang if I can find it.
@PCA7GGR - I see part of #2, 4, 5 and 8 from my list in your pic.
1. You mentioned you thought you had a couple seat belt bolts. Did you find those?
2. My front caliper pins look like the pair you have in the lower right. Mine are 77mm long. The pair of pins above them in your pic look close, but I'm not sure if they will seat with the shorter turned ends.
3. Rear pins should be shorter (69mm) and have a fat and skinny pin for each caliper. I'm not seeing them in the pic.
AA sells rear hardware kits which might be the way to go on those.
4. The plated spreaders you have at the top look like the right ones for my car. PET shows the same part# front and rear for late calipers. I think the spreaders on the bottom in your pic might be for early calipers? Mine are 51mm tall x 43mm wide.
5. I count 6 clips here. That's a good start.
8. This is a start. I have the cover plate and ratchet piece already. I need #23-29 in the diagram below. Looks like this covers 25-28. The main thing is the cable (23) as I can source the rest at the local hardware. Again, I'm pretty sure these are around somewhere but have gone missing.
Click to view attachmentSo far, I'm still looking for:
#1, #2(2), #3, #4(2), #5(2), #8 cable, and #9.Thanks guys. Sorry these parts are so tedious.
