Sorta screwed up this past Saturday. I really didn't pay attention to what I had done the previous weekend at a different track.
There were enough variables in car set up and surface, surface temps etc. that it took 4 runs just to get it better. two more and we would have had TTOD. But you never get that luxury in timed events. Lucky to just have 5 runs!!!! No fun runs so no more tweaking for next time.
This is what we have come up with so far:
Record air temp, surface temp (Smokin hot, hot, warm, cold) surface conditions (sandy, wet, dry) Car specs. Engine set up Timing, jets, etc. shift RPM launch RPM. Tire pressures Tire compounds wheel offsets. FYI no spacers Saturday either. Shock settings F/R bias (seems to affect handling alot). Sway bar settings. Ride hieght Bias Major impact on handling. With a column for effect or results from each.under steer, oversteer, Engine Pulled hard, fell on it's nose, no power, (junk it and get a bigger one). Trans gearing want to identify best spacing ratio between gears.
