Getting ready to do the dash top with the 914Rubber kit. Pretty straightforward but my original material was too far gone to serve as a template and I have one question. I know the vinyl should run long over the step down in the dash metal to terminate underneath the dash pad when it is installed, but what about the foam? Should the foam also run under the dash pad a little or should it be trimmed even with the step?
