yes like Mark said this one leaks first, to the left rear of the distributor down in the sheet metal hole with a rubber boot on top and a green with red wire connected. If leaking will be loose you can wiggle the top of it, and or have oil around it. Will have to pull off the boot first to inspect
QUOTE(Mark Henry @ Jan 5 2019, 07:49 AM)
The switch is sort of under the distributor, right above the oil cooler, look for the wire.
I would definitely install a new switch before I messed with the cooler, a lot of the time it is just the switch leaking.
