bbrock
Jan 9 2019, 09:19 AM
Got a new pair of Bilstein B6/HD shocks for rear struts. Anyone know which ring the lower perch should be adjusted to for stock ride height with stock springs? Somebody has to know.
Thanks.
Jan 9 2019, 10:08 AM
It's different depending on your springs but I would start from the 5th from the bottom. Driving a bit helps to settle everything down so you might have to adjust the front and back a bit after 50-100 miles.
