QUOTE(jsaum @ Jan 10 2019, 01:23 AM)
I have the new cam from webcam and their lifters. Is there different pitch to the gears that need to be matched to the crank gear or does the standard gear work for all?
Factory cam gears came in different +/- pitches to compensate for tooling wear during production. The replacement new gears are only available as a zero gear. Most of the time the zero gear works.
When I install a cam I install the crank and cam (nothing else) I turn over the crank and look to see if the cam lifts out of the DT bearing saddle, if loose I check for backlash. If it lifts out I put one finger on the DT cam journal, turn the crank, if it stays put with light pressure it's still OK.
The very odd time I need a +/- I pick one from my stock of used gears, which I have to modify (pump/cam bolt clearance) for the aftermarket cam.
I rarely have to do this, but I have a T1 on the bench right now that will need a modified used minus gear.
