bandjoey
Jan 19 2019, 09:53 PM
I've used this HF battery trickle charger for several years. Plug it in and forget it for weeks at a time. Very low and slow charge.rate. Then one day my battery, coil, and pertronics all fried at the same time while out on the road.
The shop said never use a trickle charger for more than 6 hours a day. They said no one really knows why everything went out at once and the long term use of this charger was possibly the cause.
Sometimes the car sits up to 2 weeks without driving it.
If I pick up a new charger do you think it should it be used for just a few hours at a time?
Will a different brand be better for our cars and how long should it be connected to the battery?
If I don't use a trickle charger how long do I need to drive the car to top off the battery?
Jan 19 2019, 10:08 PM
I know many people who use trickle chargers on their cars, Porsche’s and other high end vehicles. Some with 20-50 cars in their collections. Never heard the issue that you had.
I use this one. Works great.
Mark Henry
Jan 19 2019, 10:10 PM
If you want to leave it on all the time you need a smart charger.
For winter storage I take all of my batteries out, summer cars, lawn tractor, boat, etc. and put them on a bench (never on concrete floor) and I charge them once a month at 2amps only.
Someone who understands electronics (not me) can probably answer your question properly.
bandjoey
Jan 19 2019, 11:01 PM
What is the difference in a Battery Tender and a Smart Charger?
PlaysWithCars
Jan 20 2019, 01:51 AM
I used to use a Harbor Freight trickle charger until it cooked a battery. Switched to Battery Minder brand chargers and never looked back. Been using them for 10+ years and never had a problem. I leave them on long term but never 24/7/365 only because I have more batteries than chargers so I need to switch them around. I like the desulfation feature on them to extend battery life.
Valy
Jan 20 2019, 02:05 AM
The charger can't fry your coil, ignition since the key switch is off. It may damage the battery but only if the charger goes bad. And the type of damage to the battery will cause it to lose max voltage.
TravisNeff
Jan 20 2019, 06:05 AM
Rleog
Jan 20 2019, 06:43 AM
You might also consider CTEK smart trickle chargers. I have two of them and have been using them for years. They have settings for lead-acid and AGM batteries.
https://smartercharger.com
campbellcj
Jan 20 2019, 08:00 AM
I use a Porsche-branded CTEK (mostly on other cars) and it's great though pricey. These smart chargers automatically turn-off or cycle on/off when they detect the battery is all charged-up.
Olympic 914
Jan 20 2019, 09:52 AM
QUOTE(Rleog @ Jan 20 2019, 07:43 AM)
https://smartercharger.com CTEK - 7002 has modes for AGM and de-sulfication.
Use mine plugged into the cig lighter socket. comes with battery connection.
Only odd thing, the ends are not usual sae. but you can get an adapter.
Mark Henry
Jan 20 2019, 10:20 AM
I've used a bunch of CTEKs, many 996 customers cars have them, seen them fail to charge.
meh... I'll stick with my battery bench and charge them on a schedule.
bandjoey
Jan 20 2019, 10:42 AM
.75a 1.1a 3.5a. ?
What size is best for the 914
Amphicar770
Jan 20 2019, 11:49 AM
I keep several card on a multi-line smart battery tender, no problems. Harbor Freight charger ... I think you have your answer / culprit.
Tom_T
Jan 20 2019, 12:53 PM
Bill - as others have said -
1. For long term storage with it continuously hooked-up, you'll need the type which has the "smart" system which senses when, what & how much the battery needs for recharging, as well as when to stop charging. This is true for both the plug-in & solar types.
2. HF mostly sells low end junky stuff prone to fail - which is why they only warranty their products for 90 days, unless you pay more for an extended warranty, in order for them to cover their added costs for inevitable returns. Anything more complicated the zip ties, tape or basic tools - get it elsewhere, or at least get their extended warranty if you must buy a "smart charger" there at your own risk.
But remember that their warranty won't cover damage to anything else like your coil, etc.!
Tom
branston
Jan 20 2019, 01:07 PM
I have a few of these Schumacher maintainers attached to my cars all winter long without issues. Including my 914
I like the hook lets you hang it on the car and nice when stored 6v/12v it is used on my early vehicles too.
https://www.batterychargers.com/en/products...tery-maintainercheaper else where on line, let me Google it for you:
http://lmgtfy.com/?q=schumacher+sc2
Big Len
Jan 20 2019, 02:03 PM
If you're not using the car for 2 weeks at most, you shouldn't need a trickle charger. What's the age of your battery?
r_towle
Jan 20 2019, 11:13 PM
Smart charger will charge till full, then shut off.
It will monitor the battery and when it sees the battery go below a certain level, it will turn on and charge again.
Constant charging will melt the lead and cause a short in the battery.
UROpartsman
Jan 21 2019, 12:50 PM
QUOTE(mepstein @ Jan 19 2019, 08:08 PM)
X2, Battery Tender float chargers are very good, probably the most common model for large car collections.
Storing batteries on a concrete floor used to be an issue due to moisture, but that ended when the manufacturers started using plastic cases.
https://northeastbattery.com/do-cement-floo...-car-batteries/
bandjoey
Jan 21 2019, 03:53 PM
thanks for all the info. since I'm a shade tree mechanic, and like automated tools, the smart charger is the way to go...
amfab
Jan 21 2019, 04:17 PM
I get so paranoid that when I use a trickle charger, or any charger, I also put it on a timer so it only works for 4 or 6 hours a day.
-Andrew
Rand
Jan 21 2019, 04:25 PM
I abide by the smart charger rules. One question:
Were they made for cars?
tmc914
Jan 21 2019, 09:40 PM
[quote
[/quote]
There is no electricity available for me where I store my car so about every 2 or 3 weeks it is time for me to visit and start the car up. I let it run for about 20 min. When the snow starts to clear I try to drive it a bit near where it is stored. Car spends about 6 months in storage each year.
Jan 21 2019, 10:03 PM
You could always take your battery with you when you leave the car in storage.
90quattrocoupe
Jan 23 2019, 08:58 PM
I use this one. I got 10 years out of my trailer battery and 8 years out of the battery in my Audi.
PlaysWithCars
Jan 24 2019, 12:27 AM
QUOTE(90quattrocoupe @ Jan 23 2019, 06:58 PM)
BINGO! That's the one I have and use to maintain multiple batteries (at once). I also have one of their simpler trickle chargers w/ desulfation to hook to a single vehicle.
thelogo
Jan 24 2019, 04:09 AM
[quote name='tmc914' date='Jan 21 2019, 07:40 PM' post='2682815']
[quote
[/quote]
[/quote]
No electricity available but is there sun or solar available.
I have seen chargers wired to a solar panel . Thats better then nothing?
