Sold!
$18,000. Cash or cleared check
Will email pics on request
Porsche 914 Electric Build Components
Weight 2163 lbs. total, 1087 lbs. front, 1076 lbs. rear
23 kWh system
HPEVs AC50, 71 HP, continuous 4,000 RPM, Max 10,000 RPM
1238-7601 Curtis Controller, 96 volts, 300-800 amps
36 CALB LiFePo4 batteries, 3.2 volts, 180 amp hours
Elcon 6000 Charger
Full charge 180 amp hours, 120 volts
EV West controller chill plate and cooling kit
Elcon DC/DC converter
Andromeda Interface Display of RPM, Speed, Motor voltage, Motor temp, Controller temp, Amp hours, State of Charge voltage, BMS monitoring- average cell temp, maximum cell temp
Orion Battery Management System with CanBus readout adapter
Balanced flywheel
Heavy duty clutch plate
Engine/Trans adapter plate
Rebuilt transmission by CMS with intermediate bearing plate upgrade
Shift linkage bushings
Heavy duty Rear shocks, springs, and bushings
Heavy duty front struts and torsion rods
Front sway bar
Four 4-spoke Fuchs wheels with comp tires, Four Riviera wheels with street tires included
BMW 320i front brake calipers ( 2X stock piston diameter, 2X stock brake pad surface area)
19mm master brake cylinder (17mm stock)
Front brake rotors
Front and rear wheel bearings
