QUOTE(TonyAKAVW @ Feb 5 2019, 11:22 PM)
I'm trying to assemble a set of Boxster calipers to trailing arms and have run into a clearance issue. The threaded flanges protrude into the space where the caliper needs to sit. I'm sure I could grind those down a touch, but I'm wondering if anyone else has encountered this and what their solution was.
Click to view attachmentAssembled incorrectly. The adaptors go on the inboard side of the ears. Bleeders up on the calipers. The allens may be long and rub the rotor, grind them shorter. (threaded side should face out)
In my photo lower left are Richs. No mods were needed to fit. I did have to grind the pad base a little.
Tonys look like the older DW's or possibly Clints version. If you are running front and rear adaptors kits make sure the wider ones are on the rear, the narrower adaptors are for the front brakes.
