My passenger window has sloppy play when cranking back up. I need to level it while cranking it up.Is there a thread already on how to adjust this window problem ?
914Sixer
Feb 8 2019, 07:24 AM
What year? Different problems for early and late regulators.
elsargento
Feb 8 2019, 03:34 PM
QUOTE(914Sixer @ Feb 8 2019, 05:24 AM)
1973 1.7 late 73.
Slide the rear regulator bushing into the rear door lifter bracket. was the problem all better now with the bushing in place.
914Sixer
Feb 8 2019, 06:26 PM
Regulator has some slop built into it. Got to remember that these cars were built on the cheap. Look at the crank handle and see if the teeth are worn out and that the screw is the correct one. Last look at the regulator itself.
rhodyguy
Feb 9 2019, 09:59 AM
Check the fasteners for the rear verticle guide. There should be vert pieces in the front and rear that keep the windows from rattling in the guides.
altitude411
Feb 9 2019, 11:05 AM
scroll to the top of this thread... maybe some help for you here?
