Does anyone know what is the material inside the sun visor. There is the vinyl skin, metal frame and ????? Was it a foam or sand? Does anyone know who can restore them, mine look find but sound like they are full of sand!Click to view attachment
Feb 9 2019, 04:24 PM
its ~1/2 sheet foam. After 40-50 years it starts to crumble. The challenge in "restoring" them is the seams were heat seemed, not sewn. There is a company that does reproductions that are good and a couple people who restore the cores to like new.
rgalla9146
Feb 9 2019, 05:43 PM
It's foam inside. I know that some have had success building a jig that has parallel surfaces to provide a sort of form... like a sandwich. Then expanding foam was injected into the pivot shaft openings.....Voila ! New 'soft' rigid form in the original envelope. I suggest experimenting on your less 'pristine' examples
Dario
Feb 10 2019, 05:26 PM
QUOTE(rgalla9146 @ Feb 9 2019, 03:43 PM)
Thanks I was thinking of making a mold and trying just that. Thanks to all.
bbrock
Feb 11 2019, 03:42 PM
I'm in the same boat. Haven't found a perfect solution, but found this interesting: https://www.impactbumpers.com/forum/index.p...estoration-diy/ 914Rubber offers a visor core rebuild service but the vinyl is sewn on so don't match the originals perfectly.
I'm really interested in the spray foam approach. The only thing I could find with Google was someone mentioning they tried it with mixed results. I think if I tried it, I'd look at minimal expanding window foam which I believe sets up a little more flexible than the common stuff.
IDEFIX63
Nov 18 2019, 09:50 AM
Hi
I have just finished mines... it's not a perfect job but better than a crispy 45years old one...
Mikey914
Nov 18 2019, 11:27 AM
Nice job, As you can see it's a lot of work
