One my cars has a leaking injector. What options are out there to replace the injector? I checked online and some of the online stores list aftermarket but do they work?
Thanks
914Sixer
Feb 12 2019, 02:26 PM
Best to use all of the same kind of injector. Spray pattern and volume vary by injector. Be careful because aftermarket won't give specifications of the injector like the Bosch ones do. Kind of hit and miss, you have to go by what they say but not always correct.
Check out five-o motorsports. They have a variety of different injectors. I bought a set for my 73 2.0 but haven't put them in yet. Not bad at $350 shipped.
jmalone
Feb 13 2019, 01:12 PM
AA has reasonably priced rebuilds I bought one last Fall to replace a leaker. It works great.
jcd914
Feb 14 2019, 01:11 AM
Is it the injector body that leaks or just the hose connection to the injector. The crimped on hoses can be cut off and replaced if old and leaking. If you replace the injectors you will probably need to cut off the crimped hose that come on the injectors since the probably won't hold up to todays fuel.
Jim
wndsrfr
Feb 14 2019, 07:13 AM
QUOTE(Sea Dragon 914 @ Feb 12 2019, 12:13 PM)
Thanks
Send all four to be cleaned....I've used Witch Hunter performance...great service, they make sure they're all matched in flow...
