914ltd
Feb 12 2019, 02:39 PM
Some interesting odds and ends:
Koni rear shocks, hand tested, even resistance, no air bubbles. $60 SOLD
Heater blower for 73-73. tested, includes original clamp and rubber pad. $35
Bursch for 1.7 and 1.8. good, no muffler, add what you want or a straight pipe. $75 SOLD
Pair of 1.7 and 1.8 SSI heats. Leak tested, muffler flange getting thin but still OK. $225. pair SOLD
Flywheel, 911 1965 thru 1969 and 914/6. Nice friction surface, 2mm wear on the starter ring gear. Porsche allows 2mm cut from this surface for clean up. $175.
Set of stock, US 2.0 pistons and cylinders. Minimal wear, these are in great condition for used. Marked as paired sets 1 thru 4. Clean, ring and use. $150
Weltmeister deep sump (tuna can) $45 Small flat rate ship, $7.90
All parts plus ship from 61611.
Thanks, Brad
v82go
Feb 12 2019, 02:59 PM
Hi Brad
I will take the shocks, you can pm me shipping to 33809 and paypal info
thanks Bob
Olympic 914
Feb 12 2019, 05:41 PM
will take the Weltmeister deep sump (tuna can)
[edit] pass on the Tuna can,
porbmw
Feb 12 2019, 06:00 PM
Hi Brad
RE SSI heat exchangers.
Can you confirm that neither have been bent...ie...I bought a pair from a member, but it appears that the donor car had been hit and bent the flange on one of them, and also the pipe.
Have not, despite great effort, been able to get that side to fit on the cylinder head.
If they are straight, will buy them, with shipping to 98230
Thanks
Paul
tsvo
Feb 12 2019, 07:11 PM
Second in line for the shocks if they become available.
Mike Moss
Feb 13 2019, 09:07 AM
I'll take the Bursch. Let me know how much with shipping to Livermore,CA. 94550.
Thanks Mike
914ltd
Feb 13 2019, 09:50 AM
I have had a question about the deep sump and the inability to use a screen.
A few circles with a deburring tool and the pick up extension will twist in. It requires modifying the screen but the results should protect from any debris. Brad
I have modified these and left the bottom intact after flattening the "lumps" under the pick up.
914ltd
Feb 13 2019, 10:51 AM
QUOTE(Mike Moss @ Feb 13 2019, 07:07 AM)
Thanks Mike
Mike, I wanted to be clear this is used but in great shape. the chrome tip looks good also. Brad
Mike Moss
Feb 13 2019, 05:34 PM
QUOTE(914ltd @ Feb 13 2019, 08:51 AM)
Thanks Mike
That's ok with me.
Mike Moss
Feb 13 2019, 06:20 PM
QUOTE(Mike Moss @ Feb 13 2019, 03:34 PM)
Thanks Mike
That's ok with me. Can you post the picture ftom another angle.
914ltd
Mar 13 2019, 10:24 AM
911 flywheel, tuna can still available
