QUOTE(SteelerMike77 @ Feb 13 2019, 02:52 PM)
I just got a 74 914 from Oregon, I live in Pa. I replaced all of the fuses, everything works great, EXCEPT for the wipers, they won’t budge. I was told motor is new... ANY ideas on what might be the problem?
Thanks
Just went thru this myself. Forget the circuit number for the wipers, check your wiring diagram, but make sure you have power on it WHEN THE KEY is in the On position. Check to see if the fresh air blower motor works at the same time. The cig lighter is on the same circuit IIRC. If no power it is the relay or it's, as in my case, not making good contact within the molded receptable. Just carefully splay out the male pins on the relay to enlarge the diameter. Relay is behind the fuse panel. Trust this helps.
Don't remove the fresh air blower box to get at the leads for the wiper motor unless you absolutely have to. Putting it back together is one of the most frustrating projects to tackle on a 914. Took me two days !! Potential damage to items to high. Also ego will be hurt.
