914_7T3
Feb 14 2019, 11:57 PM
Does anyone have info or photos on the correct placement of the fuel tank pads for the tank to be positioned correctly.
My shop is having trouble seating the tank low enough for a correct installation. How much lower do the bumper pads need to be to make this work and what is the best way to install them? Here are some pics of how it sits presently. Advice is appreciated!
Click to view attachmentClick to view attachment
Larmo63
Feb 15 2019, 12:46 AM
All I can suggest is that it is a balance/wiggle act to get it in there right.
Are you sure they have the rubbers in correctly?
Nothing worse than an ill fitting rubber.
DaveO90s4
Feb 15 2019, 01:17 AM
Looks to me like your rubbers are not in place properly, preventing your unit from going all the way home - so to speak.
sb914
Feb 15 2019, 06:05 AM
use Tape at the top of the rubber to hold it in place,then remove tape once the tanks in place. The rubber sits about 1 inch from the top !
jim_hoyland
Feb 15 2019, 07:06 AM
Hold the pads in place with tape. I marked the tank to show the pads upper edge. Also, when I have a helper lowering the tank, it's easier to make those micro adjustments.
BIGKAT_83
Feb 15 2019, 08:16 AM
Rubbers need to be higher up this will lower the tank. I tape them on and then remove the tape after installing the tank.
Feb 15 2019, 08:32 AM
QUOTE(BIGKAT_83 @ Feb 15 2019, 09:16 AM)
Same here. Some painters tape will do the job.
whitetwinturbo
Feb 15 2019, 10:49 AM
..... am I the only one thinking of all the wise-guy jokes available on this thread
914_7T3
Feb 15 2019, 01:36 PM
QUOTE(whitetwinturbo @ Feb 15 2019, 08:49 AM)
I don't think so, Larmo already went there with "Nothing worse than an ill fitting rubber."
The jokes can go on for days................but I've got serious fuel tank frustrations so I'm not in the mood.
914_7T3
Feb 15 2019, 01:38 PM
Thanks to everyone who chimed in. I will take the above suggestions and try to get that sorted and provide an update.
PanelBilly
Feb 15 2019, 02:13 PM
Your lucky day. My tank is out and I’m in the garage. I used a plumber’s rubber and some gorilla tape. My tank is LineX’ed so it’s a bit thicker
914_7T3
Feb 15 2019, 02:14 PM
QUOTE(sb914 @ Feb 15 2019, 04:05 AM)
@sb914 an inch from the top of the smooth edge of the tank itself or the top of the edge that slots into the groove of the pad?
76-914
Feb 15 2019, 02:18 PM
Bob nailed it. Lift up on the tank enough to free it then lift the rubber mount a bit. Do this to both sides. The idea is to let the tank and rubber mount slide into place together. There is really only one place they will sit properly.
rjames
Feb 15 2019, 02:19 PM
In addition to getting the rubber bits in the right spot, make sure the fuel hoses underneath aren't getting in the way.
Getting the tank in the right spot should be an easy thing to do.
ValcoOscar
Feb 15 2019, 03:54 PM
Late to the party but it seems like you know what to do now.
I'm not touching any rubber rubber jokes.
Please let us know if you succeed.
Oscar
sb914
Feb 15 2019, 04:43 PM
QUOTE(914_7T3 @ Feb 15 2019, 12:14 PM)
Here’s where mine sits. It’s about a inch from the top of the shock tower.
It’s also a good idea to lengthen the fuel line for future removal. Makes it way easier with the extra length of hose .
914_7T3
Feb 15 2019, 05:49 PM
QUOTE(sb914 @ Feb 15 2019, 02:43 PM)
Click to view attachmentPerfect, this is super helpful! The fuel lines were left longer for removal and a spring was inserted so it doesn't kink. Thank you for taking the time to photograph.
Blue6
Feb 15 2019, 07:18 PM
Now that this got straightened out, I’ll piggy back on this thread. My rubber isn’t fitting correctly either. I know posts are useless without pics. Anyone want a pic.
914_7T3
Feb 15 2019, 08:10 PM
QUOTE(Blue6 @ Feb 15 2019, 05:18 PM)
Show us what you got!
ndfrigi
Feb 15 2019, 09:10 PM
well I already sent this pic to Jeffery thru text last night.
But I will just share it also here. From my previous 75 1.8FI and yes original color was copper metallic and was painted to blue by previous owner. I replaced the expansion tank to fuel tank seal a day before new owner pick-up the car.
Blue6
Feb 15 2019, 09:15 PM
QUOTE(914_7T3 @ Feb 15 2019, 06:10 PM)
I’ve got to get with SirAndy. Can’t figure out how to resize this whopper to make it fit the format.
mlindner
Feb 16 2019, 09:37 AM
Since this thread has already been hi-jacked from rubbers to whoopers, I'll add this. Guess what I'm going to use for a gas tank/fuel cell. Best, mark
Feb 16 2019, 09:58 AM
QUOTE(mlindner @ Feb 16 2019, 10:37 AM)
Click to view attachmentThat’s interesting.
rhodyguy
Feb 16 2019, 10:51 AM
What do the 2 screws on the tops of the wheelwells do?
mlindner
Feb 16 2019, 10:55 AM
Good eye rhodyguy......I made fender liners for under the GT fenders, so a few fasteners had to show, will paint later. Mark
914_7T3
Feb 18 2019, 09:36 PM
So it turns out the fuel tank was sitting fine and the expansion tank is the culprit. It literally "Expanded" during powder coating.
No wonder it would not fit.
Feb 18 2019, 09:39 PM
Maybe they put a plug on the ends to keep the powder out and the hot air blew it up. At least it's an easy part to replace.
sb914
Feb 19 2019, 07:23 AM
QUOTE(914_7T3 @ Feb 18 2019, 07:36 PM)
Click to view attachmentClick to view attachmentI think I might have one . If you want it it’s yours, I’ll look later if you want it .
marksteinhilber
Feb 19 2019, 12:29 PM
Just draw a vacuum on it and suck it back down to the right shape...
On the rubbers, just use some lube. it lets things slide into position and you can feel when they fit best. I never tape my rubbers on. Not fun when there's too much friction either. Sometimes the carpet landing strips may be too thick and it wont drop in all the way....
914_7T3
Feb 19 2019, 12:32 PM
QUOTE(sb914 @ Feb 19 2019, 05:23 AM)
Thanks
@sb914 Picking up another expansion tank today nearby so probably will not need, but will reach out if this one looks wonky.
dr914@autoatlanta.com
Feb 19 2019, 12:42 PM
pads should be a bit lower, and maybe use some silicone grease
burton73
Feb 19 2019, 01:42 PM
QUOTE(marksteinhilber @ Feb 19 2019, 10:29 AM)
Jeffrey,
I have a high vacuum pump if you want to bring it to the shop and give it a try.
Bob B
914_7T3
Feb 19 2019, 03:38 PM
QUOTE(burton73 @ Feb 19 2019, 11:42 AM)
Jeffrey,
Bob B
Totally, I have a temporary that I picked up today, just to keep things moving and mine has been PC'd already so its worth a shot!
