QUOTE(jimkelly @ Feb 17 2019, 07:27 PM)
how often do you have to start the car per week and or drive the car miles per week to keep the carbs happy and ready to go?
any other comments appreciated : )
I put Dells on my car back in the early 1980s; it was my daily driver up until 1990 or so. Since then it's been a bit of a garage queen, though I do try to drive it whenever it's anything close to "top down" weather. The car has gone up to about 3 months without driving without any problem, though I do try to run "Stabil" in the tank. FWIW, I bet I have over 100K miles on them.
Starting procedure has been connect the battery, key to "on/run" and listen for pump/fuel returning into tank, then pump accelerator about 5 times, and "start." It will usually fire on the first attempt. After a couple three "blips" it idles on its own.
I did have a carb problem a few years back--one float not floating and accelerator pump diaphragms leaking--but the carbs had been in use > 25 years at that point. Had them rebuilt at Art Thrane's place in Utah and they've been great since.
PM me if you have any questions or need additional info.
Hope this helps,
Steve A-
