yeahmag
Feb 18 2019, 11:42 PM
I have a NOS set of 96mm JE Pistons I’m thinking of using in a new build for my 914. I need rings for them. Here is what I’ve found.
Markings: JE 97M
Ring land sizes
1 - 1.5mm
2 - 1.75mm
3 - 4mm
22mm wrist pin
The ring sizes are rough as I used a crap dial caliper on the ring lands. Any additional info on them would be great! I don’t seem to have any records on these.
Mark Henry
Feb 19 2019, 07:40 AM
Contact JE direct, they use Wiseco or JE Pro Seal (japanese) rings.
JE can also supply the pins and clips if you need them. Always use new clips and they are a PITA to install, I use a clip inserter tool.
yeahmag
Feb 19 2019, 09:11 AM
I did!
“Thank you for your interest.
Do your pistons happen to have a job# on them?
We do not have rings of those dimensions, most likely whoever ordered them sourced their own ring set.”
No job number on them. John C. @ aircooled.net has rings that match. I’ve written him too.
yeahmag
Feb 19 2019, 05:58 PM
Mark Henry
Feb 20 2019, 10:37 AM
John's a good guy, if he sold them he'll fix you up. Deves are quality rings.
