914Toy
Feb 24 2019, 09:06 AM
What is the recommended front and rear toe and camber wheel alignments for our street driving 914's? And given a 16" rim, for toe adjustment: what would be the difference between the distance from the rear and the front of the wheel rim to a line parallel with the longitudinal center line of the car? Similarly, for camber adjustment what would be the difference between the top and bottom of the wheel rim from vertical? I am guessing these differences are somewhere close to 1/8" or less?
Mark Henry
Feb 24 2019, 09:35 AM
There's a real good write up, I believe it's in the classics section.
Toe in 1/8", 1.5* neg camber and for caster I like as much as you can get for high speed tracking, but it makes slow speed turning harder. IIRC I could only get 7* caster with the stock adjustment. You will run into limits with the stock adjustments, I could only get 1.75* camber on one side of the car, still OK but it may wear the inside tire a bit faster.
Rear IIRC toe out 1/8" for street.
I did my own alignment using a tilt box and a homemade toe slide ruler.
mlindner
Feb 24 2019, 10:46 AM
Mark, you have toe OUT in the rear???? I thought that was a real no no, why.
Best, Mark
jim_hoyland
Feb 24 2019, 04:40 PM
From Tech Tips 700:
worn
Feb 24 2019, 05:26 PM
QUOTE(Mark Henry @ Feb 24 2019, 07:35 AM)
Would you be willing to post some photos of home made stuff?
roblav1
Feb 24 2019, 07:10 PM
You can also use string and jackstands to measure toe. Camber and caster are also easy to measure. I use a plastic level with screws drilled in the sides. Alter the screw lengths to get the degrees desired.
Dave_Darling
Feb 25 2019, 05:34 PM
Toe out is tricky stuff, and best used in strict moderation. At the front of the car, it helps make the car turn-in faster, at the expense of it feeling twitchy and needing to be actively steered at all times. (Changing the radio station can result in an accidental lane change.) Toe-out in the rear will make the car rather more tail-happy, and is not generally a good idea unless you have a car with hideous understeer.
--DD
worn
Feb 25 2019, 06:05 PM
QUOTE(Dave_Darling @ Feb 25 2019, 03:34 PM)
--DD
Thanks. I sure noticed that with my first foray into Porsche. They go where you look! Which to me seemed dangerous and wonderful at the same time.
wndsrfr
Feb 25 2019, 08:29 PM
Toe OUT in rear....Yikes!......not sure you recall correctly.....maybe a retraction is in order?? This could be dangerous advice...
