QUOTE(cuddy_k @ Feb 25 2019, 09:49 AM)
You don't need to disconnect the cable. Just undo the single bolt holding the handle to the frame and pull it off. For the install, cut an X in the carpet for the pivot "dowel" and bolt hole. Then once the carpet is in, trim accordingly. The harder part is molding the carpet to conform to the relief in the long. You basically have to either wrestle with it, adding heat and pulling/stretching...or cut reliefs to allow the carpet to follow the contours.
But my carpet has the hole cut for the bolts along with the cut to allow for the cable to pass under the carpet when it goes over the square metal shelf leading to the back firewall. (Circled in Red) Somewhere, somehow, unless i want to cut the carpet i need to undo the cable or a point of connection.
