QUOTE(jcd914 @ Feb 25 2019, 02:43 PM)
There should be 3 connections on the backpad light.
One connection is for power to the light, hot all the time. Per the diagram should be black with red tracer.
One connection is for switched ground, connects to the door switches. Per the diagram 1 brown with white tracer.
One connection is for constant ground, so you can switch the light on with the doors closed. Per the diagram solid brown wires. The diagram I have shows 3 wires connected here but diagrams differ from reality sometimes.
The power wire should connect to the end of the light farthest from the switch.
The other ground wires should connect to the switch end of the light.
Jim
Great that should do it. Those were the three that were just hanging out there. They are all the same length so they should all go to the same spot. I'll take a closer look at the light for the 3 spades to connect to.
This site is fantastic for info. Thanks again to all for all the assistance today.
