QUOTE(GregAmy @ Feb 26 2019, 08:09 AM)
QUOTE(pneuhyde @ Feb 25 2019, 07:14 PM)
Now I need to tow my car to a new work space and found the wheels wobble around
If you've rolled your car with weight on the rear wheels, you've probably already irepairably wrecked your rear wheel bearings.
Can I mount it with the rear wheels on the dolly and and lock the steering wheel in place to tow straight...?
No, because your steering wheel will not lock in a straight-ahead position.
Thanks all for the comments and answers. I have not rolled the car without the stubs in place at all.
I had it up on all 4 corners and rebuilt all the brake calipers along with the CV's/axles (which were separated from the car already) and that is when it occurred to me that it would be easier to attach the CV's to the stubs if i pulled them out of the hub tunnel. Since the engine was out I elected to not put them back in the car for safe keeping until I was at that stage. I moved onto the master cylinder after finding it would not develop pressure after bleeding the brakes. I lowered the rear to the ground to make draining the brake fluid easy while I pulled the master cylinder. That is where it has sat, waiting for me to purchase a new 914Rubber master cylinder
And, as things go, I now have a need to move my car before I have the time to fully finish the work needed. I thought it would be less complicated to tow without the axles flopping around unattached to the transmission so i raised the rear end, installed my engine so I could move it all at once, went to check tire pressure while they were still up in the air
And found wobbly situation.
And yes, now I am concerned that even just the weight of the car sitting on them might have caused problems?
