QUOTE(ClayPerrine @ Feb 26 2019, 09:26 AM)
I found a piece of PVC pipe coupler that, with a little sanding, can be used to remove and reinstall the center caps. Use one wheel and make sure that the small end will just fit in the hole in the center, and make sure that the large end will fit over the cap and only touch the lip on the cap.
I gave away a bunch of them at Okteenerfest in 2017.
And I would suggest that you don't let the tire monkeys remove the center caps. They just hammer the center to get them out, and you end up with a badly dented cap.
Ask me how I know.......
Thanks, great advise. Yes, I delivered the wheels only to the shop, picked them up and reinstall them myself.
