QUOTE(bbrock @ Mar 1 2019, 10:34 PM)
I have my front rotors all cleaned up and plan to paint them with gray VHT high temp paint. I'm reading conflicting opinions about painting the contact area on the faces. I was thinking I'd just paint the whole thing before having them resurfaced. One camp seems to think painting the whole rotor and letting the pads take the paint off the contact area is the way to go. Makes sense for leaving only the contact area unprotected but I worry about fouling the pads. What do you experts say?
Don't paint the rotor swept surfaces. I wouldn't even recommend the zinc plating of swept surfaces.
I did design and engineering release of brakes systems as my day job. Rotor coating is a problem even within OEM industry. We used to "paint" them with a special coating to prevent rust during overseas shipment and while sitting on dealer lots (i.e. Lot Rot) to prevent judder that comes from disk thickness variation stated by localized corrosion.
Developing those coatings was a huge undertaking. When the industry was forced to switch from coatings that contained Hexavalent Chromium in the early 2000's it kicked off a switch to Zinc based coatings. We had all kinds of issues with balling of the coatings, and transfer of the coatings into the pad linings. You will not generate enough heat in the rotors to bake out the zinc once it has transferred to the pads.
Pad contamination can result in all sorts of side effects ranging from decreased friction (i.e. much longer stopping distances) to generation of brake judder, to rotor scoring.
If you do decide to paint the hats, tape off the area where the wheels contact the rotors. Having paint in the joint between the wheel and the rotor face can lead to a loss of wheel lug nut torque as the paint either crushes out or frets away over time. Loss of wheel torque rarely ever ends well. At best you get some vibrations that alert you to loss of torque. At worst, wheel will separate from the vehicle without much warning. You'd be amazed that this can happen but I assure you it can.
